Subscription help needed
OS type and version: Debian 10
Webmin version: 1.981
Virtualmin version: 6.17-3
Related products version: NextCloud Install Script
Just to get NextCloud installed I would gladly pay the subscription, but I don’t want to pay every month forever just to run one install script once… Can I pay 1 month subscription. Install Nextcloud and let the subscription lapse… Will nextcloud stop working??
Nothing stops you from installing NC manually? as for your question, it wont stop working. Virtualmin only manages the script so its easier to install and maintain. The Pro license is worth it! not just for this script.
I am running into all sorts of issues with installing NC manually. Finally bit he bullet and purchased the subscription… Installed Nectcloud via the install script and still have a similar issue… I have reached out to paid support. Hope they can get to the bottom of this.
There is a long list of prerequisites. Did you read Installation on Linux — Nextcloud latest Administration Manual latest documentation
