Always wary of starting new topics, but fully aware that is the preferred way on this forum.
I did that but it didn’t seem to do anything. The other 2 domains plus the parent domain for this sub-domain all continue to work as before but this sub-domain not using the Lets Encrypt SSL ?
I’d probably just delete and re-create the sub at this point, unless it would be ghastly difficult to rebuild. Maybe something about the missing map file in the configuration at the time it was created is preventing it from being functional now.
Some problems aren’t worth the bother to understand if an easy fix is at hand.
