After this I’ve gotten stuck. On the Apache Webmin page I see that the IP address of the virtual server is 10.170.72.60, port 80, but I get the message, “Firefox can’t establish a connection to the server at 10.170.72.60.” Clicking the domain name for the site gave me the same result. Am I going to the wrong URL, or is there some problem with the configuration of the virtual server?
It looks like that page goes about installing Virtualmin the hard way.
Our recommendation isn’t to perform a manual installation like that, but to instead install a fresh version of Ubuntu LTS (either 10.04 or 12.04), and then to use the install.sh script in the Downloads area to perform the installation and configuration of Virtualmin.
I’m not sure if that’s the reason for the error you’re getting – but with a manual install, it’s difficult to know how your system is setup, and you may save yourself a lot of trouble by using the automated install.
Is it possible to start over with a fresh install?
Yes, I’m also getting the message, “The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed,” so I think there are problems with the configuration. I wll try installing from scratch and see how it goes.
After downloading the current GPL script with wget to a fresh Ubuntu 12.04, I am also getting the ser# error. It looks like install.sh is requiring a ser# parameter to execute. Specifically, the error is:
“Serial number @SERIAL@ contains invalid characters.”
Are you sure you downloaded the correct script from the right place? I just took a look at the install script’s code, and the relevant part is as follows:
According to this code, it is impossible that the “error message and exit” are executed, except your echo or grep command behave differently than on a usual Ubuntu.
Can you verify that the install script you downloaded contains that code bit in lines 66 to 69?
That was indeed the problem. I had the pro install.sh script.
However, I’m more than a little puzzzled because, as I wrote the above query/comment, I was still in an SSH session and specifically rolled back to review the sudo wget command I had used to retrieve the file, and could swear it said …/gpl/scripts/install.sh In fact, I’m even quite sure I copied the wget from the comment at the bottom of http://www.virtualmin.com/documentation/installation/automated which clearly calls the gpl version.
Obviously, somewhere, somehow it got screwed up but I’ve no idea how. I’ve poured over the entire Virtualmin site looking for some other wget download command I might have used that was wrong, but… no “joy”. Sio I be humbled again, though I wish I knew how it happened. Oh well.
In any case, thanks for clarifying the diff between the two different install.sh scripts, as I might not have figured it out so easily otherwise. Onward.
