Stuck at starting
Ubuntu 24.04
Virtualmin version just installed with apt
I have followed the instructions to install, but it appears to be stuck at starting.
I’m not sure where to go from here as I’m not a Linux expert. Any help would be great!
sudo systemctl status webmin.service
● webmin.service - Webmin server daemon
Loaded: loaded (/lib/systemd/system/webmin.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2024-09-10 20:41:20 PDT; 16s ago
Process: 21394 ExecStart=/usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf (code=exited, status=0/SUCCESS)
Main PID: 21421 (miniserv.pl)
Tasks: 1 (limit: 38253)
Memory: 27.8M
CPU: 534ms
CGroup: /system.slice/webmin.service
└─21421 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
Sep 10 20:41:18 home-srv systemd[1]: Starting Webmin server daemon…
Sep 10 20:41:18 home-srv perl[21394]: pam_unix(webmin:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost= user=root
Sep 10 20:41:20 home-srv webmin[21394]: Webmin starting
Sep 10 20:41:20 home-srv systemd[1]: Started Webmin server daemon.
Why do you believe there is a problem? It looks like it started fine?
I can’t get to the web interface and it says it is still starting…
Solved. I didn’t add the firewall rules. Everything is good. Thanks for everyone that replied.
