**Operating system:UBUNTU Server 20.04.1
**OS version:20.04.1
I use pfsense to control traffic on my network. I installed VIRTUALMIN on UBUNTU Server 20.04.1 on vSphere 7
Ubuntu have only 1 nic added to it.
I have 2 virtual IPs added to this NIC
I have 2 virtual servers created on VIRTUALMIN and assigned 1 virtual IPs to each.
I am managing VIRTUALMIN/WEBMIN via default IP on the nic
VIRTUALMIN IP: 10.122.122.16
Virtual Server 1 IP: 10.122.122.17
Virtual Server 2 IP: 10.122.122.18
I don’t want both Virtual servers to have access to Internet only Virtualmin
but When I allow virtualmin IP address to have internet access both virtual servers have access too
What do I have to do to prevent that?
The gateway of this network is 10.122.122.1 mask /27
Should I add some routes to each IP to use gateway address or something else
Thank you
EDIT: I use pfsense to resolve hostnames domains VIRTUALMIN BIND DNS is switched OFF
Virtualmin uses ports 10000 - 10100, Usermin uses 20000 so if you keep these open and lock down all other ports via your firewall on Virtualmin or one that is further upstream, you will be able to access Virtualmin from the net but all other services on all your IPs will be inaccessible to the rest of the net nor will any processes or services on the Virtualmin server be able to access the net.
If that is indeed what you wish then I must caution you that this will impede some of the functionality of Virtualmin.
I added a second nic to UBUNTU and configured it on the different network
I also bind it WEBMIN USERMIN to this NIC IP address and now I have full control via my firewall witch goes where, but is there anything else I have to bind to this IP in order to separate the main system from all Virtual servers i.e websites?
“Virtualmin uses ports 10000 - 10100” You mean useing all ports from 10000 to 10100 ports ?
If I want to update anything on the server I have to at least open http and https then all website goes online again. is there a way I can separate virtual servers on one interface and the system to the other interface. I tried few advance routing, but nothing is working
All websites run on Apache / Nginx but Virtualmin does not, hence you can use firewall rules to access Virtualmin remotely via 10000 and keep 80 & 443 locked down.
You are attempting to overengineer a solution for what appears to be a simple problem.
I have to open those ports in order to update or upgrade anything
sudo apt update
Err:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
Could not connect to banjo.canonical.com:80 (91.189.91.38). - connect (111: Connection refused) Could not connect to kazooie.canonical.com:80 (91.189.91.39). - connect (111: Connection refused) Unable to connect to us.archive.ubuntu.com:http:
Err:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Err:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Err:4 http://us.archive.ubuntu.com/ubuntu focal-security InRelease
Err:5 http://software.virtualmin.com/vm/6/gpl/apt virtualmin-focal InRelease
Could not connect to software.virtualmin.com:80 (163.172.162.254). - connect (111: Connection refused)
Err:6 http://software.virtualmin.com/vm/6/gpl/apt virtualmin-universal InRelease
Unable to connect to software.virtualmin.com:http:
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/focal/InRelease Could not connect to banjo.canonical.com:80 (91.189.91.38). - connect (111: Connection refused) Could not connect to kazooie.canonical.com:80 (91.189.91.39). - connect (111: Connection refused) Unable to connect to us.archive.ubuntu.com:http:
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Unable to connect to us.archive.ubuntu.com:http:
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Unable to connect to us.archive.ubuntu.com:http:
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/focal-security/InRelease Unable to connect to us.archive.ubuntu.com:http:
W: Failed to fetch http://software.virtualmin.com/vm/6/gpl/apt/dists/virtualmin-focal/InRelease Could not connect to software.virtualmin.com:80 (163.172.162.254). - connect (111: Connection refused)
W: Failed to fetch http://software.virtualmin.com/vm/6/gpl/apt/dists/virtualmin-universal/InRelease Unable to connect to software.virtualmin.com:http:
W: Some index files failed to download. They have been ignored, or old ones used instead.
I can’t they all go trough a single IP 10.122.122.16
I created second interface 10.12.15.5/25 with some advanced routing tables on both interface and I still can’t do anything from my firewall
If I allow internet access on int1 :10.122.122.16 and deny on int2: 10.12.15.5 int2 still can access internet and if I allow on int2 and deny on int1, int1 still can access internet
This should be done I think with iptables. I don’t see any other option in my case
