Apache won’t start… I get the following error
Starting httpd: Syntax error on line 1052 of /etc/httpd/conf/httpd.conf:
Invalid command ‘php_admin_value’, perhaps misspelled or defined by a module not included in the server configuration
[FAILED]
Can someone help??
Have you checked that php5 is being loaded as a module?
Did this just start to happen on a working system, or is this a new build?
HI there … server was working fine… this just happened… seems like php5 is not loading… how can I fix this?
I have another server running fine and I noticed this…
Configuration file Purpose Actions
/etc/php.ini Global PHP configuration Manage Edit Manually
/opt/rh/php55/root/etc/php.ini PHP 5.5 Manage Edit Manually
Edit other PHP configuration file:
AND Problem server has only this…
.Configuration file Purpose Actions
----->missing /opt/rh/php55/root/etc/php.ini PHP 5.5 Manage Edit Manually !!
2 things…
why did this happen?
how do I fix this?
Thank you
Newbie
First thing to try is copy the /opt/rh/php55/root/etc/php.ini from the working system, and put it in the same directory as the non-working system.
The thing is, files do not have a habit of deleting themselves! So, something happened to cause this.
Joe
August 12, 2017, 1:18am
5
I would disable mod_php and remove all config directives that set mod_php options. Use mod_fcgid or php-fpm instead. mod_php is never recommended in a modern system.
server still down and Im still lost… can you help this total newbie?
Thanks,
JP
