SSL Renew Certificate Error = PLEASE HELP
Webmin version 2.101
Usermin version 2.001
Virtualmin version 7.7
Theme version 21.04
I have tries the Lets Encrypt forum and was told to try get help on virtualmin for this
PLEASE HELP
I,m wrecking my brains out on this - just can’t seem to get a certificate even renewal is failing - I’ve tried both Please bear with me on this as I’m not very technical - Hope someone out there can help
My domain is: priyaexclusives.com
I ran this command: Lets Encrypt Request Certificate
It produced this output:
Requesting a certificate for priyaexclusives.com , www.priyaexclusives.com from Let’s Encrypt …
… request failed : Web-based validation failed :
Plugins selected: Authenticator webroot, Installer None
Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org
Renewing an existing certificate for priyaexclusives.com and www.priyaexclusives.com
Reusing existing private key from /etc/letsencrypt/live/priyaexclusives.com/privkey.pem.
Performing the following challenges:
http-01 challenge for priyaexclusives.com
http-01 challenge for www.priyaexclusives.com
Using the webroot path /home/priyaexc/public_html for all unmatched domains.
Waiting for verification…
Challenge failed for domain priyaexclusives.com
Challenge failed for domain www.priyaexclusives.com
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
Is there a way to completley do a fresh new SSL request? delete all the certificates keys etc and start fresh? I have done this before but forgot how to do this
maybe that will help instad of trying to renew the old expired certificates
PLEASE HELP
ASM2
That won’t do anything useful.
You aren’t allowing access to the .well-known directory, so validation can’t work. You must allow access to .well-known. If you have any proxy rules or redirect rules setup for a web app, or whatever, they must exclude .well-known
Thanks Joe
Had to find a way to allow access and it
Worked fine…
You’re the BEST!
Thanks again
Regards
ASM2
