for each of this domains i have either self-signed or registered ssl certificates (wildcard). each running on a different ip.
with normal subdomains (for example roundcube on netmail.xyz.com) this solution works pretty nice. but unfortunately not for the webmin/virtualmin part.
as soon as i press copy to webmin this certificate is issued for all domains and overwrites all others, it’s somehow not per ip (as it would make sense).
any idea how i could make webmin available under a subdomain which then is covered with wildcard ssl?
otherwise i have to let all server user connect through one url, instead using their own accounts.
Well, most folks do indeed use one SSL certificate for their Virtualmin installation – and I suspect what’s happening is that chosing “Copy to Webmin” is always overwriting whatever SSL cert is currently installed there.
To use a setup such as that – you could also configure the Apache Website option in Server Templates to redirect admin.domain.tld to one specific URL, a URL where SSL is configured.
However, to do what you’re describing – while “Copy to Webmin” won’t work, you could always go into Webmin -> Webmin -> Webmin Configuration -> SSL Encryption -> Per-IP certificates, and configure your desired SSL certificates for each of the IP addresses on your server.
thanks for the last input, i guess i have to check this out. but at the moment i have other huge issues, dkim is aparently not working anymore, well what’s going on these days…
