SSL Interface 'nit'
This made me wonder a few times when I first started. There is nothing to indicate this is already the setting you’ve chosen and in place. I thought it meant I hadn’t chosen it. Once ‘set’ it should change to ‘unset’ to indicate it is the active configuration. Or disappear? Not sure really what the best alternative would/should be.
Yes it does.
Used by services
[details=“Webmin, Usermin, Dovecot, Postfix, ProFTPD, MariaDB, BIND”]
Globally by
By domain
vom-bruch.com
also the button turns orange and says Remove from services.,
Screenshot 2026-06-04 221515
I have NO orange buttons. So maybe it is a distro specific thing? Been this way since the beginning for me.
Webmin version 2.641
Usermin version 2.540
Virtualmin version 8.1.0 GPL
Theme version 26.41
Apache version 2.4.67
WTF. You can clearly see above it didn’t take. Has ALWAYS been that way for me. Now, I just check all of my domains and it does? I’m going to bed.
