SSL / HTTPS Issue
Hey Guys,
I was trying to install webmin this morning and got the error:
pi@nas4:~ $ wget http://www.webmin.com/jcameron-key.asc
--2022-01-20 03:11:09--  http://www.webmin.com/jcameron-key.asc
Resolving www.webmin.com (www.webmin.com)... 216.105.38.11
Connecting to www.webmin.com (www.webmin.com)|216.105.38.11|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.webmin.com/jcameron-key.asc [following]
--2022-01-20 03:11:09--  https://www.webmin.com/jcameron-key.asc
Connecting to www.webmin.com (www.webmin.com)|216.105.38.11|:443... connected.
ERROR: The certificate of ‘www.webmin.com’ is not trusted.
ERROR: The certificate of ‘www.webmin.com’ has expired.
The certificate has expired
I honestly am not sure if it’s legit or not just thought you should know.
Wasn’t sure where to post this so I came here.
Thanks,
Michael
Looks like the entire Webmin site is having SSL issues.
Try running:
wget http://prdownloads.sourceforge.net/webadmin/webmin_1.984_all.deb
Then run:
apt-get install ./webmin_1.984_all.deb
If you’re using Virtualmin, you should not install Webmin from the Webmin repos.
It looks like Jamie has updated the cert for that link, though, so you should be able to fetch it now.
