neill
January 25, 2023, 7:34am
1
OS type and version
Ubuntu 22.04.1
Webmin version
2.013
Virtualmin version
7.50pro
When trying to access the remote api via either curl or python’s request library I get an SSL error.
In python:
url = f"https://{args.server}:10000/virtual-server/remote.cgi?program=list-domains"
resp = requests.get(url,auth=(args.user, args.password))
results in
ssl.SSLError: ("read error: Error([('SSL routines', '', 'unexpected eof while reading')])",)
From wget:
wget --http-user root --http-passwd='<redacted>' 'https://<redacted>:10000/virtual-server/remote.cgi?program=list-domains'
results in a loop of:
2023-01-25 18:29:54 (31.8 KB/s) - Read error at byte 3214 (The TLS connection was non-properly terminated.).Retrying.
wget does return output, but the SSL exception means I can’t access the response body in python.
Any suggestions as to how to fix this?
neill
January 25, 2023, 9:41pm
2
Further information - the ssl certificate is from letsencrypt and is valid.
suther
January 26, 2023, 10:29am
3
Not a full solution, but a workaround, if you just need to use / test the API urgently, and want to look later on for the SSL issue:
You can use wget with skipping ssl-check with parameter: --no-check-certificate
neill
January 27, 2023, 6:01am
4
The SSL cert is valid, and the error occurs even if validation is turned off.
For now I’m just tunneling over ssh and running the cli.
neill
February 8, 2023, 12:19am
5
Still have this issue, is there another way I should be asking for support?
I asked chagpt. curl it suggest. (on your first example)
curl -k -u admin:password https://hostname:10000/virtual-server/remote.cgi?program=list-domains
for python is suggests, , using the requests library:
import requests
url = “https://hostname:10000/virtual-server/remote.cgi?program=list-domains ”
headers = {
‘Authorization’: ‘Basic ’ + b64encode(b’admin:password’).decode(“utf-8”)
response = requests.get(url, headers=headers, verify=False)
print(response.content)
Since you’re on Pro, let’s tag @staff
Jamie
February 8, 2023, 5:10am
8
Does anything get logged to /var/webmin/miniserv.error when you get this SSL error from wget ?
GENLTD
February 8, 2023, 10:40am
9
This is a known bug with openssl (see their git #18866 for more info). The solution (if it can be called that) is to pass “SSL_OP_IGNORE_UNEXPECTED_EOF” to openssl, which bypasses the error since the actual request works ok (in my case anyway).
If you’re using PHP’s curl, then you’re stuffed because there’s no way to pass it to openssl, so the option (for me) was to switch to Pear’s HTTP/Request2 which still bleats but carries on regardless.
There will no doubt be a fix in the pipes but for now this is what ya got.
system
Closed
April 9, 2023, 10:41am
10
