Hi everyone. I’m pretty new dealing with servers and SSL configs. This is my first VPS server.
I got this SSL certificate on Virtualmin. I chose the option with wildcard, cause I had the idea to with subdomains.
It created the files and the certificate, but the SSL doesn’t work even on the main domain. I don’t know where the mistake is.
If someone can help me I appreciate that.
yes definately use the “KISS” principle for starting out. Only go for a standard certificate for www.yourdomain.com and yourdomain.com (these should be the default already preselected in virtualmin)
Dont forget to ensure that you have the following dns records
As long as you have the above dns records, and they are resolving it should work.
You can check if your dns is resolving by using the free https://mxtoolbox.com online checker! (it has quite a few alternative testing tools ie mx, spf, reverse ptr, dkim, _dmarc, dns…etc etc). I use it extensively.
