Here are the two config files, thank you for the assistance!
When we also provide SSL we have to listen to the
the HTTPS port in addition.
Listen 443
Listen 192.168.1.20:81
Listen 192.168.1.20:444
SSL Global Context
All SSL configuration in this context applies both to
the main server and all SSL-enabled virtual hosts.
Pass Phrase Dialog:
Configure the pass phrase gathering process.
The filtering dialog program (`builtin’ is a internal
terminal dialog) has to provide the pass phrase on stdout.
SSLPassPhraseDialog exec:/usr/libexec/httpd-ssl-pass-dialog
Inter-Process Session Cache:
Configure the SSL Session Cache: First the mechanism
to use and second the expiring timeout (in seconds).
SSLSessionCache shmcb:/run/httpd/sslcache(512000)
SSLSessionCacheTimeout 300
Pseudo Random Number Generator (PRNG):
Configure one or more sources to seed the PRNG of the
SSL library. The seed data should be of good random quality.
WARNING! On some platforms /dev/random blocks if not enough entropy
is available. This means you then cannot use the /dev/random device
because it would lead to very long connection times (as long as
it requires to make more entropy available). But usually those
platforms additionally provide a /dev/urandom device which doesn’t
block. So, if available, use this one instead. Read the mod_ssl User
Manual for more details.
SSLRandomSeed startup file:/dev/urandom 256
SSLRandomSeed connect builtin
#SSLRandomSeed startup file:/dev/random 512
#SSLRandomSeed connect file:/dev/random 512
#SSLRandomSeed connect file:/dev/urandom 512
Use “SSLCryptoDevice” to enable any supported hardware
accelerators. Use “openssl engine -v” to list supported
engine names. NOTE: If you enable an accelerator and the
server does not start, consult the error logs and ensure
your accelerator is functioning properly.
SSLCryptoDevice builtin
#SSLCryptoDevice ubsec
SSL Virtual Host Context
<VirtualHost 192.168.1.13:443>
General setup for the virtual host, inherited from global configuration
#DocumentRoot “/var/www/html”
#ServerName www.example.com:443
Use separate log files for the SSL virtual host; note that LogLevel
is not inherited from httpd.conf.
ErrorLog logs/ssl_error_log
TransferLog logs/ssl_access_log
LogLevel warn
SSL Engine Switch:
Enable/Disable SSL for this virtual host.
SSLEngine on
SSL Protocol support:
List the enable protocol levels with which clients will be able to
connect. Disable SSLv2 access by default:
SSLProtocol +TLSv1 +TLSv1.1 +TLSv1.2
SSL Cipher Suite:
List the ciphers that the client is permitted to negotiate.
See the mod_ssl documentation for a complete list.
SSLCipherSuite HIGH:MEDIUM:!aNULL:!MD5
Speed-optimized SSL Cipher configuration:
If speed is your main concern (on busy HTTPS servers e.g.),
you might want to force clients to specific, performance
optimized ciphers. In this case, prepend those ciphers
to the SSLCipherSuite list, and enable SSLHonorCipherOrder.
Caveat: by giving precedence to RC4-SHA and AES128-SHA
(as in the example below), most connections will no longer
have perfect forward secrecy - if the server’s key is
compromised, captures of past or future traffic must be
considered compromised, too.
#SSLCipherSuite RC4-SHA:AES128-SHA:HIGH:MEDIUM:!aNULL:!MD5
#SSLHonorCipherOrder on
Server Certificate:
Point SSLCertificateFile at a PEM encoded certificate. If
the certificate is encrypted, then you will be prompted for a
pass phrase. Note that a kill -HUP will prompt again. A new
certificate can be generated using the genkey(1) command.
#SSLCertificateFile /etc/pki/tls/certs/localhost.crt
SSLCertificateFile /home/foo.com/ssl.cert
Server Private Key:
If the key is not combined with the certificate, use this
directive to point at the key file. Keep in mind that if
you’ve both a RSA and a DSA private key you can configure
both in parallel (to also allow the use of DSA ciphers, etc.)
#SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
SSLCertificateKeyFile /home/foo.com/ssl.key
Server Certificate Chain:
Point SSLCertificateChainFile at a file containing the
concatenation of PEM encoded CA certificates which form the
certificate chain for the server certificate. Alternatively
the referenced file can be the same as SSLCertificateFile
when the CA certificates are directly appended to the server
certificate for convinience.
#SSLCertificateChainFile /etc/pki/tls/certs/server-chain.crt
Certificate Authority (CA):
Set the CA certificate verification path where to find CA
certificates for client authentication or alternatively one
huge file containing all of them (file must be PEM encoded)
#SSLCACertificateFile /etc/pki/tls/certs/ca-bundle.crt
Client Authentication (Type):
Client certificate verification type and depth. Types are
none, optional, require and optional_no_ca. Depth is a
number which specifies how deeply to verify the certificate
issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
Access Control:
With SSLRequire you can do per-directory access control based
on arbitrary complex boolean expressions containing server
variable checks and other lookup directives. The syntax is a
mixture between C and Perl. See the mod_ssl documentation
for more details.
#SSLRequire ( %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
and %{SSL_CLIENT_S_DN_O} eq “Snake Oil, Ltd.” \
and %{SSL_CLIENT_S_DN_OU} in {“Staff”, “CA”, “Dev”} \
and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20 ) \
or %{REMOTE_ADDR} =~ m/^192.76.162.[0-9]+$/
SSL Engine Options:
Set various options for the SSL engine.
o FakeBasicAuth:
Translate the client X.509 into a Basic Authorisation. This means that
the standard Auth/DBMAuth methods can be used for access control. The
user name is the `one line’ version of the client’s X.509 certificate.
Note that no password is obtained from the user. Every entry in the user
file needs this password: `xxj31ZMTZzkVA’.
o ExportCertData:
This exports two additional environment variables: SSL_CLIENT_CERT and
SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
server (always existing) and the client (only existing when client
authentication is used). This can be used to import the certificates
into CGI scripts.
o StdEnvVars:
This exports the standard SSL/TLS related `SSL_*’ environment variables.
Per default this exportation is switched off for performance reasons,
because the extraction step is an expensive operation and is usually
useless for serving static content. So one usually enables the
exportation for CGI and SSI requests only.
o StrictRequire:
This denies access when “SSLRequireSSL” or “SSLRequire” applied even
under a “Satisfy any” situation, i.e. when it applies access is denied
and no other module can change it.
o OptRenegotiate:
This enables optimized SSL connection renegotiation handling when SSL
directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<Files ~ “.(cgi|shtml|phtml|php3?)$”>
SSLOptions +StdEnvVars
<Directory “/var/www/cgi-bin”>
SSL Protocol Adjustments:
The safe and default but still SSL/TLS standard compliant shutdown
approach is that mod_ssl sends the close notify alert but doesn’t wait for
the close notify alert from client. When you need a different shutdown
approach you can use one of the following variables:
o ssl-unclean-shutdown:
This forces an unclean shutdown when the connection is closed, i.e. no
SSL close notify alert is send or allowed to received. This violates
the SSL/TLS standard but is needed for some brain-dead browsers. Use
this when you receive I/O errors because of the standard approach where
mod_ssl sends the close notify alert.
o ssl-accurate-shutdown:
This forces an accurate shutdown when the connection is closed, i.e. a
SSL close notify alert is send and mod_ssl waits for the close notify
alert of the client. This is 100% SSL/TLS standard compliant, but in
practice often causes hanging connections with brain-dead browsers. Use
this only for browsers where you know that their SSL implementation
works correctly.
Notice: Most problems of broken clients are also related to the HTTP
keep-alive facility, so you usually additionally want to disable
keep-alive for those clients, too. Use variable “nokeepalive” for this.
Similarly, one has to force some clients to use HTTP/1.0 to workaround
their broken HTTP/1.1 implementation. Use variables “downgrade-1.0” and
“force-response-1.0” for this.
BrowserMatch “MSIE [2-5]”
nokeepalive ssl-unclean-shutdown
downgrade-1.0 force-response-1.0
Per-Server Logging:
The home of a custom SSL log file. Use this when you want a
compact non-error SSL logfile on a virtual host basis.
CustomLog logs/ssl_request_log
“%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x “%r” %b”
httpd.conf
This is the main Apache HTTP server configuration file. It contains the
configuration directives that give the server its instructions.
In particular, see
for a discussion of each configuration directive.
Do NOT simply read the instructions in here without understanding
what they do. They’re here only as hints or reminders. If you are unsure
consult the online docs. You have been warned.
Configuration and logfile names: If the filenames you specify for many
of the server’s control files begin with “/” (or “drive:/” for Win32), the
server will use that explicit path. If the filenames do not begin
with “/”, the value of ServerRoot is prepended – so ‘log/access_log’
with ServerRoot set to ‘/www’ will be interpreted by the
server as ‘/www/log/access_log’, where as ‘/log/access_log’ will be
interpreted as ‘/log/access_log’.
ServerRoot: The top of the directory tree under which the server’s
configuration, error, and log files are kept.
Do not add a slash at the end of the directory path. If you point
ServerRoot at a non-local disk, be sure to specify a local disk on the
Mutex directive, if file-based mutexes are used. If you wish to share the
same ServerRoot for multiple httpd daemons, you will need to change at
least PidFile.
ServerRoot “/etc/httpd”
Listen: Allows you to bind Apache to specific IP addresses and/or
ports, instead of the default. See also the
directive.
Change this to Listen on specific IP addresses as shown below to
prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
Dynamic Shared Object (DSO) Support
To be able to use the functionality of a module which was built as a DSO you
have to place corresponding `LoadModule’ lines at this location so the
directives contained in it are actually available before they are used.
Statically compiled modules (those listed by `httpd -l’) do not need
to be loaded here.
Example:
LoadModule foo_module modules/mod_foo.so
Include conf.modules.d/*.conf
If you wish httpd to run as a different user or group, you must run
httpd as root initially and it will switch.
User/Group: The name (or #number) of the user/group to run httpd as.
It is usually good practice to create a dedicated user and group for
running httpd, as with most system services.
User apache
Group apache
‘Main’ server configuration
The directives in this section set up the values used by the ‘main’
server, which responds to any requests that aren’t handled by a
definition. These values also provide defaults for
any containers you may define later in the file.
All of these directives may appear inside containers,
in which case these default settings will be overridden for the
virtual host being defined.
ServerAdmin: Your address, where problems with the server should be
e-mailed. This address appears on some server-generated pages, such
ServerAdmin root@localhost
ServerName gives the name and port that the server uses to identify itself.
This can often be determined automatically, but we recommend you specify
it explicitly to prevent problems during startup.
If your host doesn’t have a registered DNS name, enter its IP address here.
#ServerName www.example.com:80
Deny access to the entirety of your server’s filesystem. You must
explicitly permit access to web content directories in other
blocks below.
AllowOverride none
Require all denied
Note that from this point forward you must specifically allow
particular features to be enabled - so if something’s not working as
you might expect, make sure that you have specifically enabled it
below.
DocumentRoot: The directory out of which you will serve your
documents. By default, all requests are taken from this directory, but
symbolic links and aliases may be used to point to other locations.
Relax access to content within /var/www.
<Directory “/var/www”>
AllowOverride None
# Allow open access:
Require all granted
Further relax access to the default document root:
<Directory “/var/www/html”>
# Possible values for the Options directive are “None”, “All”,
# or any combination of:
# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# Note that “MultiViews” must be named explicitly — “Options All”
# doesn’t give it to you.
# The Options directive is both complicated and important. Please see
# http://httpd.apache.org/docs/2.4/mod/core.html#options
# for more information.
Options Indexes FollowSymLinks
# AllowOverride controls what directives may be placed in .htaccess files.
# It can be "All", "None", or any combination of the keywords:
# Options FileInfo AuthConfig Limit
AllowOverride None
# Controls who can get stuff from this server.
Require all granted
DirectoryIndex: sets the file that Apache will serve if a directory
is requested.
DirectoryIndex index.html
The following lines prevent .htaccess and .htpasswd files from being
viewed by Web clients.
<Files “.ht*”>
Require all denied
ErrorLog: The location of the error log file.
If you do not specify an ErrorLog directive within a
container, error messages relating to that virtual host will be
logged here. If you do define an error logfile for a
container, that host’s errors will be logged there and not here.
ErrorLog “logs/error_log”
LogLevel: Control the number of messages logged to the error_log.
Possible values include: debug, info, notice, warn, error, crit,
alert, emerg.
LogLevel warn
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
<IfModule logio_module>
# You need to enable mod_logio.c to use %I and %O
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
</IfModule>
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here. Contrariwise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
#CustomLog "logs/access_log" common
# If you prefer a logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
CustomLog "logs/access_log" combined
# Redirect: Allows you to tell clients about documents that used to
# exist in your server's namespace, but do not anymore. The client
# will make a new request for the document at its new location.
# Example:
# Redirect permanent /foo http://www.example.com/bar
# Alias: Maps web paths into filesystem paths and is used to
# access content that does not live under the DocumentRoot.
# Example:
# Alias /webpath /full/filesystem/path
# If you include a trailing / on /webpath then the server will
# require it to be present in the URL. You will also likely
# need to provide a <Directory> section to allow access to
# the filesystem path.
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the target directory are treated as applications and
# run by the server when requested rather than as documents sent to the
# client. The same rules about trailing "/" apply to ScriptAlias
# directives as to Alias.
ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
“/var/www/cgi-bin” should be changed to whatever your ScriptAliased
CGI directory exists, if you have that configured.
AllowOverride None
Options None
Require all granted
# TypesConfig points to the file containing the list of mappings from
# filename extension to MIME-type.
TypesConfig /etc/mime.types
# AddType allows you to add to or override the MIME configuration
# file specified in TypesConfig for specific file types.
#AddType application/x-gzip .tgz
# AddEncoding allows you to have certain browsers uncompress
# information on the fly. Note: Not all browsers support this.
#AddEncoding x-compress .Z
#AddEncoding x-gzip .gz .tgz
# If the AddEncoding directives above are commented-out, then you
# probably should define those extensions to indicate media types:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
# AddHandler allows you to map certain file extensions to "handlers":
# actions unrelated to filetype. These can be either built into the server
# or added with the Action directive (see below)
# To use CGI scripts outside of ScriptAliased directories:
# (You will also need to add "ExecCGI" to the "Options" directive.)
#AddHandler cgi-script .cgi
# For type maps (negotiated resources):
#AddHandler type-map var
# Filters allow you to process content before it is sent to the client.
# To parse .shtml files for server-side includes (SSI):
# (You will also need to add "Includes" to the "Options" directive.)
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
Specify a default charset for all content served; this enables
interpretation of all content as UTF-8 by default. To use the
default browser choice (ISO-8859-1), or to allow the META tags
in HTML content to override this choice, comment out this
directive:
AddDefaultCharset UTF-8
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type. The MIMEMagicFile
# directive tells the module where the hint definitions are located.
MIMEMagicFile conf/magic
Customizable error responses come in three flavors:
1) plain text 2) local redirects 3) external redirects
Some examples:
#ErrorDocument 500 “The server made a boo boo.”
#ErrorDocument 404 /missing.html
#ErrorDocument 404 “/cgi-bin/missing_handler.pl”
#ErrorDocument 402 http://www.example.com/subscription_info.html
EnableMMAP and EnableSendfile: On systems that support it,
memory-mapping or the sendfile syscall may be used to deliver
files. This usually improves server performance, but must
be turned off when serving from networked-mounted
filesystems or if support for these functions is otherwise
broken on your system.
Defaults if commented: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
EnableSendfile on
Supplemental configuration
Load config files in the “/etc/httpd/conf.d” directory, if any.
IncludeOptional conf.d/.conf
SSLProtocol +SSLv3 +TLSv1 +TLSv1.1 +TLSv1.2
SSLCipherSuite HIGH:!SSLv2:!ADH:!aNULL:!eNULL:!NULL
ServerTokens Minimal
ServerSignature Off
TraceEnable Off
LoadModule php5_module /etc/httpd/modules/libphp5.so
<FilesMatch .php$>
SetHandler application/x-httpd-php
<VirtualHost 192.168.1.20:80>
SuexecUserGroup “#502” “#502”
ServerName foo.com
ServerAlias www.foo.com
ServerAlias webmail.foo.com
ServerAlias admin.foo.com
DocumentRoot /home/foo/public_html
ErrorLog /var/log/virtualmin/foo.com_error_log
CustomLog /var/log/virtualmin/foo.com_access_log combined
ScriptAlias /cgi-bin/ /home/foo/cgi-bin/
ScriptAlias /awstats/ /home/foo/cgi-bin/
<Directory /home/foo/public_html>
Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch +ExecCGI
allow from all
Require all granted
AddType application/x-httpd-php .php
AddType application/x-httpd-php5 .php5
<Directory /home/foo/cgi-bin>
allow from all
Require all granted
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.foo.com
RewriteRule ^(.) https://foo.com:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.foo.com
RewriteRule ^(.) https://foo.com:10000/ [R]
AuthName “foo.com statistics”
AuthType Basic
AuthUserFile /home/foo/.awstats-htpasswd
require valid-user
Alias /dav /home/foo/public_html
<Location /dav>
DAV on
AuthType Basic
AuthName “foo.com”
AuthUserFile /home/foo/etc/dav.digest.passwd
Require valid-user
ForceType text/plain
Satisfy All
RemoveHandler .php
RemoveHandler .php5
RewriteEngine off
SetEnv ODBCSYSINI /etc
SetEnv ODBCINI /etc/odbc.ini
<VirtualHost 192.168.1.20:443>
ServerName foo.com
allow from all
Require all granted
allow from all
Require all granted
RewriteEngine on
RewriteRule ^(.*) https://foo.com:10000/ [R]
AuthType Basic
require valid-user
<Location /dav>
DAV on
AuthType Basic
AuthName “foo.com”
Require valid-user
Satisfy All
RemoveHandler .php
RemoveHandler .php5
RewriteEngine off
SSLEngine on
SSLCertificateFile /home/foo/ssl.cert
SSLCertificateKeyFile /home/foo/ssl.key
SSLCACertificateFile /home/foo/ssl.ca
