Hi everyone!
I tried following @Joe’s tutorial on YouTube so my website runs over https … but I failed miserably!
When asking for Let’s Encrypt certificates, VM defaults to my domain and its www, mail, autoconfig and autodiscover subdomains … those are not in the tutorial and I am not in fact sure how to use the latter 3 (yes, not even the mail subdomain) …
Let’s Encrypt gives several errors when requesting certs for the latter 3:
- The following errors were reported by the server:
Domain: autoconfig.site.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for
autoconfig.site.com - check that a DNS record exists for
this domain
Domain: autodiscover.site.com
Type: dns
autodiscover.site.com - check that a DNS record exists for
this domain
Domain: mail.site.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for mail.site.com
- check that a DNS record exists for this domain
and trying to pass the DNS-based validation:
Type: dns
Detail: DNS problem: NXDOMAIN looking up TXT for
_acme-challenge.autoconfig.site.com (http://_acme-challenge.autoconfig.giganteazul.com/) - check that a DNS
Type: dns
_acme-challenge.autodiscover.site.com (http://_acme-challenge.autodiscover.giganteazul.com/) - check that a DNS
Type: dns
_acme-challenge.mail.site.com (http://_acme-challenge.mail.giganteazul.com/) - check that a DNS record
I don’t have any records at my registrar that point to any of those subdomains … I don’t know what the point would be with two of them, but I guess one of them I will be using when I try to set up my mail server.
Anyway… I just went for the second option and listed my domain and the www subdomain. (Which is the default in @Joe’s videotutorial) Success! The request at Let’s Encrypt is comes through! Now the theory says my site is running HTTPS … I wish!!
I don’t know what the problem is. I have tried installing a WordPress plug-in that forces SSL, but it did not do the trick.
I have run a test on https://www.ssllabs.com/ and the results were negative:
Short version:
Assessment failed: Unable to connect to the server
Long version:
**Known Problems**
There are some errors that we cannot fix properly in the current version. They will be addressed in the next generation version, which is currently being developed.
* **No secure protocols supported** - if you get this message, but you know that the site supports SSL, wait until the cache expires on its own, then try again, making sure the hostname you enter uses the "www" prefix (e.g., "www.ssllabs.com", not just "ssllabs.com").
* **no more data allowed for version 1 certificate** - the certificate is invalid; it is declared as version 1, but uses extensions, which were introduced in version 3. Browsers might ignore this problem, but our parser is strict and refuses to proceed. We'll try to find a different parser to avoid this problem.
* **Failed to obtain certificate** and **Internal Error** - errors of this type will often be reported for servers that use connection rate limits or block connections in response to unusual traffic. Problems of this type are very difficult to diagnose. If you have access to the server being tested, before reporting a problem to us, please check that there is no rate limiting or IDS in place.
* **NetScaler issues** - some NetScaler versions appear to reject SSL handshakes that do not include certain suites or handshakes that use a few suites. If the test is failing and there is a NetScaler load balancer in place, that's most likely the reason.
* **Unexpected failure** - our tests are designed to fail when unusual results are observed. This usually happens when there are multiple TLS servers behind the same IP address. In such cases we can't provide accurate results, which is why we fail.
**Common Error Messages**
* **Connect timed out** - server did not respond to our connection request, sometimes before we are dynamically blocked when our tests are detected
* **No route to host** - unable to reach the server
* **Unable to connect to server** - failed to connect to the server, it usually happens due to firewall restrictions
* **Connection reset** - we got disconnected from the server
* **Unrecognized SSL message, plaintext connection?** - the server responded with plain-text HTTP on HTTPS port
* **Received fatal alert: handshake_failure** - this is either a faulty SSL server or some other server listening on port 443; if the SSL version of the web site works in your browser, please report this issue to us
* **Failed to communicate with the secure server** - No secure protocol supported. Possibly this server only supports a draft version of TLS 1.3
If I go to my BIND DNS server and look in the master zone for my site … it shows that I have 1 record for certificate authorities but 0 records for SSL certificates … which doesn’t look right.
