SSL certificate for Owncast Apache instance on port 8080
OS type and version Debian 12
Virtualmin version 8.1.0 GPL
I’m trying to get an Owncast instance working on a Debian 12 Apache server.
I put the Owncast executable at /opt/owncast. Opened ports 8080 and 1935 in Firewalld. Created owncast service.
Tried to get a working Apache config for separate virtual server (a subdomain) following the Apache config on the Owncast website.
I didn’t know how to specify the SSL certificate, so I just copied the SSL paths of the main virtual server.
That didn’t work. Http works - the Owncast instance is accessible.
But https doesn’t work.
I set Virtualmin to always go to the SSL site.
How do I get SSL working for a port?
This is /etc/apache2/sites-available/owncast.conf
<VirtualHost *:80>
        ServerName live.communitykirtan.com
        ServerAdmin kirtan@communitykirtan.com
        Redirect permanent / https://live.communitykirtan.com
</VirtualHost>
# live-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
        ProxyRequests       Off
        ProxyPreserveHost   On
        AllowEncodedSlashes NoDecode
        ProxyPass        / http://localhost:8080/ upgrade=websocket
        ProxyPassReverse / http://localhost:8080/
        RequestHeader    set X-Forwarded-Proto "https"
        RequestHeader    set X-Forwarded-Port "443"
        SSLCertificateFile /etc/ssl/virtualmin/1775330264488674/ssl.cert
        SSLCertificateKeyFile /etc/ssl/virtualmin/1775330264488674/ssl.key
        Include /etc/letsencrypt/options-ssl-apache.conf
        SSLCACertificateFile /etc/ssl/virtualmin/1775330264488674/ssl.ca
</VirtualHost>
</IfModule>
This is /etc/apache2/sites-available/live.communitykirtan.com.conf
<VirtualHost *:80>
    SuexecUserGroup #1005 #1004
    ServerAlias www.live.communitykirtan.com
    ServerAlias mail.live.communitykirtan.com
    ServerAlias webmail.live.communitykirtan.com
    ServerAlias admin.live.communitykirtan.com
    DocumentRoot /home/live/public_html
    ErrorLog /var/log/virtualmin/live.communitykirtan.com_error_log
    CustomLog /var/log/virtualmin/live.communitykirtan.com_access_log combined
    ScriptAlias /cgi-bin/ /home/live/cgi-bin/
    ScriptAlias /awstats /home/live/cgi-bin/awstats.pl
    DirectoryIndex index.php index.htm index.html
    <Directory /home/live/public_html>
        Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch
        Require all granted
        AllowOverride All Options=ExecCGI,Includes,IncludesNOEXEC,Indexes,MultiViews,SymLinksIfOwn
erMatch
    </Directory>
    <Directory /home/live/cgi-bin>
        Require all granted
erMatch
    </Directory>
    ProxyPass /.well-known !
    RewriteEngine on
    RewriteCond %{HTTP_HOST} =webmail.live.communitykirtan.com
    RewriteRule ^/(?!\.well-known)(.*)$ https://live.communitykirtan.com:20000/ [R=301,L]
    RewriteCond %{HTTP_HOST} =admin.live.communitykirtan.com
    RewriteRule ^/(?!\.well-known)(.*)$ https://live.communitykirtan.com:10000/ [R=301,L]
    RemoveHandler .php
    RemoveHandler .php8.2
    RemoveHandler .php8.4
    RedirectMatch ^/awstats$ /awstats/
    <FilesMatch \.php$>
        SetHandler proxy:unix:/run/php/1775330264488674.sock|fcgi://127.0.0.1
    </FilesMatch>
    <Files awstats.pl>
        AuthName "live.communitykirtan.com statistics"
        AuthType Basic
        AuthUserFile /home/live/.awstats-htpasswd
        require valid-user
    </Files>
    RewriteRule ^/(?!.well-known)(.*)$(.*)$ https://%{HTTP_HOST}/$1$1 [R]
I did this some while ago, however it only appeared to work correctly using nginx. however I ditched owncast in favour of rtmp which tbf has been rock steady for over a year
I’m even worse at nginx than apache. Great that you got it working with nginx.
Are you going the strictly rtmp route, without the chat feature of Owncast?
I built my own chat app (?) That sits next to the rtmp window a bit like owncast.
I ran nginx concurrently with apache so the web side is rendered by apache and the rtmp/opencast is served via nginx and then just put into a frame in the apache website
Wow! Building your own chat is impressive!
Nice bit of tech work to customize the server the way you want!
