SSL Cert Revoked - Locked out of VM Pro - Emergancy
I can’t pull up VM anymore, get (Error code: sec_error_revoked_certificate)
How can I create a new SSL cert from the command line?
I found these in /etc/httpd/conf/httpd.conf
SSLCertificateFile /home/domain/ssl.cert
SSLCertificateKeyFile /home/domain/ssl.key
Not sure how to generate this; or do I just comment it out? Which is what I did.
SSLCACertificateFile /home/domain/ssl.ca
Command I used:
openssl genrsa -out ssl.key 2048
openssl req -new -key ssl.key -out ssl.csr
openssl x509 -req -days 365 -in ssl.csr -signkey ssl.key -out ssl.cert
I have recreated them as a self signed key, but it didn’t work; I’m missing something simple.
I had a signed SSL on here, I moved it to a new server; but I still need this server to work without it; I wonder if it has something to do with the agency revoking the original cert; but now that I resigned this one, I don’t know what the issue is.
This is server is at a remote location hundreds of miles away; so all I have is ssh access.
If I have a web site setup on the main domain that has an SSL cert, and it expires, how does VM continue to work? This is basically what happened, I moved the cert to another server; not knowing this would happen; who would think it would lock me out of VM.
I have created a Signed cert and replaced it, yet I still can not get into VM; any idea’s?
Tools > Options > Advanced > Encryption > Validation > Disable OCSP.
This got me in; now I can fix it; thanks for all the help.
