You can use jailkit, but to use jailkit you must be aware that all resources that the user needs must be placed in the jail, you also may have to alter the users environment to get the best experience. That said for what reason does a domain owner ssh access ? As most things that a domain owner may need are in the virtualmin/usermin panels. I don’t give Domain owners ssh access, I point them to the relevant function in Vmin/Umin.
Is there a default set of commands & environment that Vmin will set up auto setup so PHP will work out of the box (sendmail for example) or does the user still have to manually enter these ?
hmm php will not work out of the box as I see the following
jail@server:~/public_html$ sendmail
bash: sendmail: command not found
jail@server:~/public_html$ clear
TERM environment variable not set.
So therefore you need to adjust your statement to read ‘this works on el but not on debian systems’ rather than ‘a pro user can do this’ as it from your statement it does not work using debian
If we’re shipping improvements to jail support, making it easier to get a PHP environment is probably one of the obvious ease-of-use improvements. I’m surprised the RPM has a configuration that the Debian package doesn’t have, though. I guess it’s a version issue (i.e. added to Jailkit recently)?
Edit: What I mean by that last bit is that if a newer version of the package will have it, we should just encourage people to use new versions of their OS, rather than working around it by shipping our own.
But, also, I don’t know how we make it clear that folks need to understand Jailkit in order to use it safely!
I think the more we add UI enhancements that make it seem like an easy thing to do, the more likely someone will make mistakes that make their jails breakable (which is actually extremely dangerous on Debian/Ubuntu where the Jailkit binaries do not use capabilities and are running as full root, at least, last time I checked…the RPM uses capabilities, so it’s much safer).
The distinction lies in the packaging differences between EL and Debian distributions. Specifically, in the EL distribution, jk_init includes a defined [php] section, whereas this section is absent in the Debian distribution.
However, this difference should not affect our users, thanks to a new feature in Virtualmin Pro that automates the process. Users simply need to add php to the Extra commands and directories for Jailkit to copy field, and the system will handle the rest seamlessly.
