Spot the difference
Webmin version 2.520
Usermin version 2.420
Virtualmin version 7.50.0 GPL
Theme version 25.20
Nginx version 1.24.0
as many will know I run several VM with GPL on various OS from various suppliers around the world.just love Virtualmin :heart:
one of my problems is keeping up :old_man:
I have just noticed something rather odd with the Dashboard of two VM. (both OS = Ubuntu)
and
what has happened to the Virtual Memory
virtual memory is Swap space. you probably didn’t create a swap partition during OS installation. (you can add a swap file in installed system, if needed).
nothing to do with virtualmin.
created as standard on all VM :disappointed_face:
cannot think of anyway it would have been removed upstream. was looking for some way to check, or if there had been some other interference/hacking
I’d say it’s a coin toss these days, if the provider images have swap enabled or not.
seems to indicate it is there at least to me
and owned correctly :cat_with_wry_smile:
don’t know why - just taken the VM through a boot cycle (nothing to update) but just thought it would clear the air :+1:
and it did just that - now back to showing 4 dials
I had a teacher that owned a calculator with a print out. In his wallet he carried a printout that obviously had the math wrong. In his case it was to prove to his math students that estimating your expected answer isn’t a waste of time. But here? Computers glitch. :zany_face:
