Spamassassin 3 - Pyzor, Razor, DCC questions
I installed Razor, Pyzor and dcc with apt on a debian etch server, and set the spamassassin config.
When I restart the mail system I get the following error messages in my mail.log:
config: failed to parse line, skipping: auto_learn_threshold_spam 5.5
config: failed to parse line, skipping: auto_learn_threshold_nonspam 1.9
config: failed to parse, now a plugin, skipping: ok_languages de en
config: failed to parse line, skipping: dcc_add_header 1
SpamAssassin failed to parse line, "/usr/sbin/dccifd" is not valid for "dcc_dccifd_path", skipping: dcc_dccifd_path /usr/sbin/dccifd
config: failed to parse line, skipping: pyzor_add_header 1
SpamAssassin failed to parse line, no value provided for "use_auto_whitelist", skipping: use_auto_whitelist
do all the commands not work anymore on spamassassin >=3 ??
but when i look at my spam log it seems that pyzor and dcc is working though.
spamd: identified spam (15.1/5.0) for user.domain:1014 in 9.1 seconds, 3700 bytes.
Feb 15 20:37:18 alpha spamd[2587]: spamd: result: Y 15 - DATE_IN_PAST_06_12,DCC_CHECK,DIGEST_MULTIPLE,HTML_MESSAGE,PYZOR_CHECK,URIBL_JP_SURBL,URIBL_SBL scantime=9.1,size=3700,user=user.domain,uid=1014,required_score=5.0,rhost=myhostname,raddr=127.0.0.1,rport=60279,mid=<01c86fe9$3bb77100$ae31f057@blake>,autolearn=spam
I’ve read that the default thresohold for autolearning is set to 12. how can I set it to a lower value if the things I set in the local.cf seem to do not work. Or whats the ‘failed to parse’ telling me?
