I don’t believe it’s possible to get rid of “Excluded Directories” without directly modifying the theme.
Regarding “Change Password” – is there any particular reason you’d like to disable that? I just want to make sure I can’t assist with a better solution.
For example, some people disable that because it, by default, changes the MySQL password too – which breaks PHP apps.
But that’s fixable by going into System Settings -> Server Templates -> Default -> MySQL, and setting "Update MySQL password to match server to “No”.
Ok, that worked, and how can I do the same for the JAVA File manager? The settings of the FileManager in Usermin have no effects, only the one in Webmin. But there I can’t set the public_html dir.
Someone got Piwik running with Virtualmin? I’ve installed the latest Virtualmin-Analytics module, and Piwik but it seems not to include the script automatically in the header of the .php files.
