Hi I am not that clued up on DNS hence I can’t get subdomains setup and working with virtualmin. I have spent a couple of days now and have read many post here but none that are simple enough for me to understand as a non server administrator.
I have my domains with 1and1, in their control panel is an option to create a subdomain which I have. The info displays that A and MX records are created and the domain is under control of
Name server 1&1 name server
IP Address (A-Record) 1&1 IP
Mail Server (MX Record) 1&1 mail server
How exactly do I set up the sub-domain at the virtualmin end, I’ve tried top level and subsever and read much on bind and I’m confused as hell as to how to complete what I’m sure Is propably very simple.
Creating a sub-domain in Virtualmin is the same as creating a regular domain… except that a sub-domain takes slightly longer to type
To create a sub-domain, go into “Create Virtual Server”, and rather than adding a domain name like “example.com”, put in “sub.example.com”.
That’s it!
If you want your sub-domain to belong to an existing account, after going into Create Virtual Server, you may want to click the “Sub-Server” option at the top.
Thanks for your prompt reply, I had already tried that but now I have done it again and still not working, interestingly I cant ping it either, does this mean that the problem is with 1and1. Do I need to be using A or CNAME records?
Ok thankyou for your help so far, perhaps I should wait awhile incase the new subdomain name is still propergating, as I guess that’s whats stopping it from pinging as the TLD of the sub pings fine.
