Some errors with timeout and setting up installation 18.04
Followed installing this on 18.04
https://vpsfix.com/4937/install-virtualmin-nginx-php-mysql-ubuntu/
Got this error till timeout
Im also waiting already 20 min same last line untill you stopped it :slight_smile: Created symlink /etc/systemd/system/multi-user.target.wants/mariadb.service → /lib/systemd/system/mariadb.service
Job for mariadb.service failed because a timeout was exceeded. See “systemctl status mariadb.service” and “journalctl -xe” for details. Setting up mariadb-server (1:10.1.44-0ubuntu0.18.04.1)
Processing triggers for libc-bin (2.27-3ubuntu1)
Processing triggers for systemd (237-3ubuntu10.39)
Processing triggers for man-db (2.8.3-2ubuntu0.1)
Processing triggers for ureadahead (0.100.0-21)
Enter current password for root (enter for none): ERROR 2002 (HY000): Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2 “No such file or directory”)
Frozen on this did reboot and again from start still frozen for 30min around and then
MySQL could not be started with the new configuration :
. The old configuration has been restored.
This what is preventing me from switching to Ubuntu 18.04 for the last year or so. Installation would work if you still with MySQL. But MariaDB isn’t working for some reason. I didn’t bother to troubleshoot it because Ubuntu 16.04 with MariaDB is still working great.
