Hi i have just installed Virtualmin and there was a system check button at the top of the admin section. after running this i get the following message.
"The status of your system is being checked to ensure that all enabled features are available, that the mail server is properly configured, and that quotas are active …
The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin base directory is /home. CGI and PHP scripts run as domain owners will not be executed.
… your system is not ready for use by Virtualmin."
I’m running ubuntu 9.04 and used the install.sh script to install Virtualmin.
I decided to do a little test and created a virtual server (by that i assume it means a virtual host for a website) and added ftp and email.
before i uploaded any files i went to domain.tld. it showed me the default apache index.html in /var/www/ that says “It works!”. i then logged in via ftp and uploaded a phpinfo file (info.php). On going to domain.tld again it still showed the default index.html page created by apache. so i went to domain.tld/info.php and it said that the file could not be found.
i also performed a virtual server check on the domain and go this:
"Beginning validation of selected virtual servers. Any problems found will be shown in red …
domain.tld
BIND DNS domain : The following errors were found in the DNS records : dns_rdata_fromtext: /etc/bind/domain.tld.hosts:9: near ‘::1’: bad dotted quad
dns_rdata_fromtext: /etc/bind/domain.tld.hosts:10: near ‘::1’: bad dotted quad
dns_rdata_fromtext: /etc/bind/domain.tld.hosts:11: near ‘::1’: bad dotted quad
dns_rdata_fromtext: /etc/bind/domain.tld.hosts:12: near ‘::1’: bad dotted quad
dns_rdata_fromtext: /etc/bind/domain.tld.hosts:14: near ‘::1’: bad dotted quad
dns_rdata_fromtext: /etc/bind/domain.tld.hosts:15: near ‘::1’: bad dotted quad
dns_rdata_fromtext: /etc/bind/domain.tld.hosts:16: near ‘::1’: bad dotted quad
zone domain.tld/IN: loading from master file /etc/bind/domain.tld.hosts failed: bad dotted quad"
Email and FTP work perfectly it’s just this at the moment.
how can i fix the problems that i am having?
Thanks in advanced
TheAshMan
PS. does Virtualmin have an irc channel?
hi Eric, thanks for the reply!
i think you might have a good point about reinstalling. at least 8.04 is supported and most people would be able to help if errors occurred.
I shall reinstall if that is the main point in agreement.
i just reinstalled with 8.04 and installed Virtualmin.
I still get this error when rechecking the configuration:
I am running on a VPS and my VPS host is amazing when it comes to OS reloads.
Yes i did install via the install.sh script as well this time.
here you go:
“cat: /etc/issue/: not a directory”
also here you go: root@vps12:/# clear
root@vps12:/# dpkg -l ‘apache2*’
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Installed/Config-f/Unpacked/Failed-cfg/Half-inst/t-aWait/T-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Name Version Description
pn apache2 (no description available)
un apache2-common (no description available)
ii apache2-doc 2.2.8-1ubuntu0.9 documentation for apache2
un apache2-mpm (no description available)
un apache2-mpm-event (no description available)
un apache2-mpm-itk (no description available)
ii apache2-mpm-prefork 2.2.8-1ubuntu0.9 Traditional model for Apache HTTPD
un apache2-mpm-worker (no description available)
ii apache2-utils 2.2.8-1ubuntu0.9 utility programs for webservers
ii apache2.2-common 2.2.8-1ubuntu0.9 Next generation, scalable, extendable web server
also a quick question: when it comes to hosting websites, do i use my hostname as the dns server? or do i have to add the a names and such myself?
Regarding #2 above, it looks like you have a slash on the end there. Try like this, without a trailing slash:
cat /etc/issue
However, in general, what you’re seeing should never happen! It looks like, for whatever reason, the installer didn’t add on the Virtualmin Apache packages.
But in using Ubuntu 8.04, we can help easier
Is there any chance you could post your /root/virtualmin-install.log file?
We can use that to figure out where things went awry.
From there, we should either be able to point you in the right direction, or just fix it ourselves, since that should work
I’m going to shoot Joe a quick email to get his thoughts – but how would you feel if he or I logged in to take a look at what’s going on?
There might be something with the repository setup there that’s causing the installer to not behave right. Or there could just be a bug in the installer. Or some combination of the above, I’m not sure yet
If you don’t mind one of us logging in, what we would need is root login info. You can email that to eric@virtualmin.com – if you can, include a link to this forum post in the message body.
I meant to update this earlier – for anyone else running into this, the issue was that the Virtualmin installer hadn’t replaced the existing Ubuntu Apache packages with the Virtualmin packages.
The fix was to run an “apt-get upgrade”, and it was all set!
This will be corrected in a future install script release.
The “Bad dotted quad” issue was because Virtualmin wasn’t correctly detecting the external interface being used under OpenVZ. It used venet0, rather than venet0:0.
That will be corrected in Virtualmin 3.70 (but could also be manually corrected by setting the interface in Module Config -> Network Settings).
hello Eric, first of all I must say I’m totally newbie and here is the situation:
When I first install haved the same issue with suexec. Read the post an do it.
Now when Re-Check Config, I receive “… your system is ready for use by Virtualmin.” but
always will be a but
On System Information, my Apache Webserver is DOWN.
When I try to start it: Failed to start service :
Starting web server apache2
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
…fail!
So I take a look in Webmin/System/Running Processes and here I have:
31717 www-data 09:08 /usr/sbin/apache2 -k start
From here I’m stuck. can you help me with some ideas?
Tks
obs: I run a totally manual setup Ubuntu 8.04 LTS Server. Kernel Linux 2.6.24-24-server on x86_64. Virtualmin version 3.74.gpl GPL.
Also tried with standard Ubuntu auto LAMP install and I encountered the same problems.
I think I installed the OS at last 6 times with different setup config/procedures and of course the same issues.
The f…king CentOS running out of the box (on other machine) but I prefer Ubuntu.
