Here is an interesting file:
Default Server Any Any Automatic Automatic Open..
Virtual Server Any 80 Automatic /var/www/vhosts/ Open..
Virtual Server 209.208.24.242 80 scoutfishing.com /home/scoutfishing/public_html Open..
Select all. | Invert selection.
When I created the domain through virtualmin, I had specified the IP as being 209.208.24.243. I have since gone in and manually edited this in this file. I have also edited the other virtual server to have it’s files go to /home/.
Before either Webmin or Virualmin were installed, I had bound a range of IPs to this server through /etc/network/interfaces.
[code]root@epsilon:/home/scoutfishing/public_html# cat /etc/network/interfaces
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
auto eth0 eth0:1 eth0:2 eth0:3 eth0:4 eth0:5 eth0:6 eth0:7 eth1 eth1:1 eth1:2 eth1:3 eth1:4 eth1:5
iface eth0 inet static
address 209.208.24.242
netmask 255.255.255.240
network 209.208.24.240
broadcast 209.208.24.255
gateway 209.208.24.241
iface eth0:1 inet static
address 192.168.2.120
netmask 255.255.255.0
network 192.168.2.1
broadcast 192.168.2.255
iface eth0:2 inet static
address 209.208.24.244
iface eth0:3 inet static
address 209.208.24.246
iface eth0:4 inet static
address 209.208.24.248
iface eth0:5 inet static
address 209.208.24.250
iface eth0:6 inet static
address 209.208.24.252
iface eth0:7 inet static
address 209.208.24.254
iface eth1 inet static
address 209.208.24.243
iface eth1:1 inet static
address 209.208.24.245
iface eth1:2 inet static
address 209.208.24.247
iface eth1:3 inet static
address 209.208.24.249
iface eth1:4 inet static
address 209.208.24.251
iface eth1:5 inet static
address 209.208.24.253
[/code]
I want to use 242 and 244 as “shared” Ips for domains that won’t have a secured portion to them. I want to use all the other IPs for specific domains. I believe I found this option in Virtualmin when I created this. Unfortunately, when I went to check it in DNS, it shows THIS:
Name TTL Address
scoutfishing.com. Default 209.208.24.242
www.scoutfishing.com. Default 209.208.24.242
ftp.scoutfishing.com. Default 209.208.24.242
m.scoutfishing.com. Default 209.208.24.242
Name TTL Address
localhost.scoutfishing.com. Default 127.0.0.1
webmail.scoutfishing.com. Default 209.208.24.242
admin.scoutfishing.com. Default 209.208.24.242
