I’m testing Virtualmin for the purpose to migrate some projects that now run on cPanel servers. I did a fresh install on a clean Debian 10 VPS using the following command:
sh ./install.sh --bundle LEMP --minimal
The VPS will not be used as mailserver, so I chose the minimail install. After the wizard, I have the following screen:
**The status of your system is being checked to ensure that all enabled features are available, that the mail server is properly configured, and that quotas are active ..**
Your system has 3.76 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB.
Postfix can support per-domain outgoing IP addresses, but is not currently configured to do so. This can be setup in the [Postfix Mailserver](https://server.nodusweb.it:10000/postfix/dependent.cgi) module.
The following PHP versions are available : 7.3.11 (/bin/php-cgi7.3)
The following PHP-FPM versions are available on this system : 7.3.11 (php7.3-fpm)
PHP versions have changed to 7.3 since last check. Regenerating any missing php.ini files.
MariaDB 10.3.18 is installed and running.
ProFTPD is installed.
Logrotate is installed.
The AWstats command /usr/lib/cgi-bin/awstats.pl was not found on your system.
**.. your system is not ready for use by Virtualmin.**
My questions are:
- why is the system not ready? What should I do to make it ready?
- why I miss the AWstats command?
- Why do I have Postfix even If I chose the minimal install?
