Hi, i am moving my website to another server but it cant be reaced by the public.
Intodns (https://intodns.com/apilix.com)
Server have been fresh installed on ubuntu 16.04
Picture of New Virtual IP address (Server Configuration > Change IP address)
DNS Records
Re-Check Config
Postfix is configured to support per-domain outgoing IP addresses.
Apache is installed.
The following PHP versions are available : 7.0.8 (/usr/bin/php-cgi7.0)
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPD is installed.
Logrotate is installed.
Plugin AWstats reporting is installed OK.
Plugin Protected web directories is installed OK.
Using network interface eno1 for virtual IPs.
Default IPv4 address for virtual servers is 192.168.1.220.
Both user and group quotas are enabled for home and email directories.
All commands needed to create and restore backups are installed.
The selected package management and update systems are installed OK.
… your system is ready for use by Virtualmin.
I have tried a few stuff i found on the forums. But that didnt work.
This link is kind of the same problem as mine (https://www.virtualmin.com/node/38026) Tried to do the same, but i still get the error.
It also gives me error when i try to resolve my nameservers. "unable to resolve nameserver to an IP address
UPDATE
If i go to the external IP i get the default Apache website
Checked Ports in Router.
http://prntscr.com/csy601 - Ports are open.
Update 2 ***
Ran command
dig apilix.com
Output
; <<>> DiG 9.10.3-P4-Ubuntu <<>> apilix.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 27336
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;apilix.com. IN A
;; ANSWER SECTION:
apilix.com. 38400 IN A 79.160.144.62
;; AUTHORITY SECTION:
apilix.com. 38400 IN NS ns1.apilix.com.
apilix.com. 38400 IN NS ns2.apilix.com.
;; ADDITIONAL SECTION:
ns1.apilix.com. 38400 IN A 79.160.144.62
;; Query time: 0 msec
;; SERVER: ::1#53(::1)
;; WHEN: Wed Oct 12 17:36:13 CEST 2016
;; MSG SIZE rcvd: 107
