Hi!
I’ve searched the threads but I can’t seem quite to find the answer, other than that someone with my exact problem fixed by reinstalling.
First off, I went to DKIM under “Email Messages” in Virtualmin, clicked the “Install Now” button, and everything appeared to go well without any errors. My DNS is off-server, so first I listed all my domains for which I use email under “Additional domains to sign for”. Then I carefully copied the information from Virtualmin’s “DNS records for additional domains” into TXT records for each of my domains DNS.
So far, so good, but now, when I try sending email, I get the error in the message headers “dkim=temperror (no key for signature) header.i=@beedrives.com”
When I test at http://dkimcore.org/c/keycheck (with selector “beehive”) I get the error “A public-key (p=) is required”
But checking my domain in Terminal with “dig txt beedrives.com” I see the public key showing up properly.
I tried disabling and reenabling DKIM signing, to no avail. I reboot the server, again to no avail.
When I reenabled DKIM, I made note of the following (again, all seemed to go well):
Finding virtual servers to enable DKIM for …
… no virtual servers with DNS and email enabled were found, but enabling for 7 extra domains
Extracting public key from private key in /etc/dkim.key …
… done
Setting domain and selector in DKIM filter configuration …
… done
Enabling DKIM filter at boot time …
… done
Starting DKIM filter …
… done
Configuring mail server to use DKIM filter …
… done
I’m using CentOS Linux 6.8, Webmin version 1.801, Virtualmin version 5.03
What might I be doing wrong at this point?
Thanks so much!
Elise
Thank you so so much for uploading that image, I must have overlooked that critical little piece in the help files I read, and not realized the TXT record for DKIM had to have the odd selector._domainkey syntax in the subdomain field! I just fixed all my other domains too. Thank you!!!
