Hello
I tried to create a subserver and it failed because /home/parent-server/domains does not exists.
I tried to manually create domains folder, but it’s sill failing because it does not create subserver folders into domains parent folder.
The errors are when trying to copy php.ini files, and awstat reporting folder, and at the end domains/subserver folder is empty
