| SYSTEM INFORMATION | |
| OS type and version | Rocky Linux 9.3 |
| Webmin version | 2.105 |
| Usermin version | 2.005 |
| Virtualmin version | 7.9.0 Pro |
| Theme version | 21.09.5 |
| Package updates | All installed packages are up to date |
In the Virtualmin Show Email Client Setting it recommends
This fails for me I have to use SSL on port 465 to send email, if I use the above I get timeout straight away no delay unlike normal timeouts. Port 587 is Open.
Is this a recommended incorrect or do I need to enable something in postfix?
If I do this would be a bug.
P.S.
I found this in postfix
Should this be set to yes
Ok, not sure whats going on, I set to yes and stopped and started Postfix and it started working reload wasn’t enough.
I then set to No and stopped and started postfix and still worked.
So its a mystery what going on, but it working now.
