SMTP Banner Mismatch with PTR Record on Multi-IP Virtual Servers
Webmin version 2.621
Virtualmin version 8.0.0 Professional
Webserver version Apache 2.4.58
Related packages Postfix 3.8.6
Summary
After migrating cPanel virtual servers to Virtualmin and creating new virtual servers with dedicated IPs, MXToolbox reports SMTP Banner Check: Status Warning for newly created domains, while migrated domains pass. This post documents the root cause and fix.
Problem Description
Symptom: MXToolbox SMTP Banner Check fails with warning:
SMTP Reverse DNS Mismatch: PTR resolves to mail.example.com
SMTP Banner Check: FAILED - Banner shows example.com
Observation:
  • cPanel migrated domains with dedicated IPs: SMTP banner check PASSES
  • Newly created Virtualmin domains with dedicated IPs: SMTP banner check FAILS
Root Cause Analysis
PTR Record Configuration
Both migrated and new domains have PTR records configured correctly:
dig -x 203.0.113.100 +short
mail.example.com.
SMTP Banner Difference
Migrated domain (PASSES):
echo "QUIT" | nc -w5 10.10.50.100 25
220 mail.example.com ESMTP Postfix
New Virtualmin domain (FAILS):
echo "QUIT" | nc -w5 10.10.50.101 25
220 example.com ESMTP Postfix
Postfix master.cf Analysis
For virtual servers with dedicated IPs, Virtualmin creates per-IP listeners in /etc/postfix/master.cf:
Migrated from cPanel:
10.10.50.100:smtp inet n - y - - smtpd ... -o myhostname=mail.example.com
Created in Virtualmin:
10.10.50.101:smtp inet n - y - - smtpd ... -o myhostname=example.com
The difference: cPanel migrations preserve mail.domain.com in myhostname, while Virtualmin sets it to the bare domain domain.com.
Source Code Location
The behavior originates in /usr/share/webmin/virtual-server/feature-ssl.pl at line 2739:
push(@flags, [ "myhostname", $d->{'dom'} ]);
This sets myhostname to the bare domain name ($d->{'dom'}) rather than the mail subdomain.
Solution
Fix for Existing Domains
Add mail. prefix to all myhostname entries in master.cf:
# For each domain, run:
sed -i 's/myhostname=example\.com/myhostname=mail.example.com/g' /etc/postfix/master.cf
# Reload Postfix
postfix reload
# Verify
echo "QUIT" | nc -w5 <internal-ip> 25
Fix for Future Domains (Permanent Fix)
Modify the Virtualmin source to prepend mail. to the hostname:
# Backup original
cp /usr/share/webmin/virtual-server/feature-ssl.pl /usr/share/webmin/virtual-server/feature-ssl.pl.bak
# Apply fix
sed -i 's/push(@flags, \[ "myhostname", \$d->{'"'"'dom'"'"'} \]);/push(@flags, [ "myhostname", "mail.".$d->{'"'"'dom'"'"'} ]);/' /usr/share/webmin/virtual-server/feature-ssl.pl
Before:
After:
push(@flags, [ "myhostname", "mail.".$d->{'dom'} ]);
Verification
After applying fixes:
# Test SMTP banner
echo "QUIT" | nc -w5 <ip-address> 25
# MXToolbox should now show:
# SMTP Reverse DNS Mismatch: OK - resolves to mail.example.com
# SMTP Banner Check: OK - Reverse DNS matches SMTP Banner
Important Notes
  1. PTR Records: Ensure all dedicated IP PTR records are set to mail.domain.com format
  2. Webmin Updates: This fix modifies Virtualmin source code and may be overwritten by updates. Re-apply after upgrading Virtualmin.
  3. Scope: This only affects the SMTP banner (Postfix greeting). It does NOT affect:
  • Web hosting (www.domain.com)
  • SSL certificates
  • DNS records
  • Any other services
Feature Request
It would be beneficial if Virtualmin provided a configuration option for the SMTP banner hostname format, allowing administrators to choose between:
  • domain.com (current default)
  • mail.domain.com (common for PTR matching)
  • Custom template (e.g., ${MAIL_SUBDOMAIN}.${DOMAIN})
This would eliminate the need to modify source files and survive updates.
my reverse dns is something.example.com and that banner check still passes with mail.example.com I assumed it goes for the MX record.
Hey @lawk
That’s interesting, your case shows the check was lenient with different subdomains something vs mail. My issue was with dedicated IPs using external reverse DNS (not Virtualmin DNS), where bare domain vs subdomain example.com vs mail.example.com consistently failed.
