SMTP auth refused with sasl error
I had several errors reported like this:
SASL LOGIN authentication failed: authentication failure
I searched and googled, and googled and searched…
Never found a solution that would solve my problem.
I had a similar problem with imap and pop3 login.
Wanted the user to authenticate as user@domain.tld instead of user-domain.tld or user.domain.tld
Some research on virtualmin and webmin foruns pointed me to the right direction…
And today, I tried to use the user-domain.tld format and my emails started to be sent.
I’ve been using qmail since forever, and was trying postfix. Have been testing the spam and virus filtering for some months now, and I decided it was time for a definitive change.
There was the problem with sending emails. I wish someone could point me where to enable the use of:
user@domain.tld in smtp auth.
Thanks.
If you haven’t already, you may want to take a peek in System Settings -> Server Templates -> Default -> Mail for Domain, and verify that “Format for usernames that include domain” is set the way you want it. (which sounds like it would be the user@domain format).
That will only change new email accounts that are created… any existing account will continue to use the previous style.
If you’ve created a new email account using the user@domain format, and it still doesn’t allow you to log in, you’d want to make sure that saslauthd is running with the -r option.
You can verify that by looking at the running process, which you can do with this command:
“ps auxw | grep saslauth”
If it does not have the -r option, we can get that fixed, just let us know what distro you’re using :slight_smile:
Here is the output to ps auxw | grep saslauth
root 27000 0.0 0.0 5564 488 ? Ss 14:24 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 27001 0.0 0.0 5608 980 ? S 14:24 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 27002 0.0 0.0 5564 264 ? S 14:24 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 27003 0.0 0.0 5564 264 ? S 14:24 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 27004 0.0 0.0 5564 264 ? S 14:24 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 31563 0.0 0.0 3916 680 pts/0 S+ 16:10 0:00 grep saslauth
I can login any user (before or after the change on default address format) on pop3.
But can only send emails, using smtp, if I change the user format to user-domain instead of user@domain.
Webmail, works flawless.
Yeah, due to the way saslauthd works, it has to be running with the -r option in order to handle users in the format of user@domain. Saslauthd is the daemon responsible for handling secure email sending.
It your case, it doesn’t look like saslauthd is running with -r. We can get that fixed, though you didn’t mention what distro you were using :slight_smile:
Operating system CentOS Linux 5.2
Webmin version 1.500
Virtualmin version 3.77.gpl GPL
Theme version 7.7
Kernel and CPU Linux 2.6.18-92.1.22.el5 on i686
So, can you be so kind, and help me? I’m used to qmail. But it is getting really hard to admin a mail server using it. Now that I’ve been using Postfix, for myself, installed with webmin, I decided that is a better solution to serve my clients.
Thanks.
On CentOS, to get saslauthd running with the -r flag, you can log into your server over SSH as root, and edit:
/etc/sysconfig/saslauthd
At the bottom where it says “FLAGS=”, change that line to read:
FLAGS=-r
Then, restart saslauthd with:
/etc/init.d/saslauthd restart
At that point, it should allow you to login with user@domain username formats.
And it was as simples as that!
Thank you so much!
if one configures FLAGS=-r will the regular method still work?
I needed to enable name@tld.com for just one virtual domain of those I host, so I added the FLAGS=-r config.
This was several weeks ago. Today, I observed that several accounts being hosted on that server have started having problems with email, and generating errors. Specifically:
saslauthd[6153]: do_auth : auth failure: [user=xxxxxx@dddddd.com] [service=smtp] [realm=dddddd.com] [mech=pam] [reason=PAM auth error]
Any ideas?
I believe so – think there’s been other folks who had used both username styles on the same server.
In the error you’re seeing there, it looks like the username having problems is in the user@domain.com format, which is what using -r should correct.
Two things you may want to verify –
One, make certain that saslauthd is still running with the -r parameter (you can verify that by running “ps auxw | grep saslauthd”).
Two, verify that you can login as that user in Usermin.
Thsi worked on centos any idia for debian or ubuntu?
Thanks in advance
SOLVED:
EDIT
/etc/default/saslauthd
TO
OPTIONS="-c -m /var/spool/postfix/var/run/saslauthd"
PARAMS="-m /var/spool/postfix/var/run/saslauthd -r"
RESTART
ystemctl restart saslauthd
Check! :wink:
First, I would really like to thank the VirtualMin team for the amazing product! I actually regret not trying this earlier!
On the issue of this thread, I have tried making the changes to my Debian 9 install, and the last two lines on my /etc/default/saslauthd looks like this:
And, the output of “ps” looks like this:
root@test01:~# ps auxw | grep saslauth
root 614 0.0 0.2 68712 2444 ? Ss 12:38 0:00 /usr/sbin/saslauthd -a pam -c -m /var/spool/postfix/var/run/saslauthd -n 5
root 615 0.0 0.0 68712 832 ? S 12:38 0:00 /usr/sbin/saslauthd -a pam -c -m /var/spool/postfix/var/run/saslauthd -n 5
root 616 0.0 0.0 68712 832 ? S 12:38 0:00 /usr/sbin/saslauthd -a pam -c -m /var/spool/postfix/var/run/saslauthd -n 5
root 617 0.0 0.0 68712 832 ? S 12:38 0:00 /usr/sbin/saslauthd -a pam -c -m /var/spool/postfix/var/run/saslauthd -n 5
root 618 0.0 0.0 68712 832 ? S 12:38 0:00 /usr/sbin/saslauthd -a pam -c -m /var/spool/postfix/var/run/saslauthd -n 5
root 6412 0.0 0.2 12716 2252 pts/2 S+ 12:39 0:00 grep saslauth
It doesn’t see to be running with the “-r” flag. Any help regarding this?
Regards
NYAMUL HASSAN
