SMTP 550 relay not permitted, authentication required
Wait a second.
192.168.1.201 is not my Webmin IP. Why is that there?
odd request can you add your port to your mail server address
and maybe try different ports like so
prime1.inleed.net:25 something like that or prime1.inleed.net:2525 or prime1.inleed.net:587 errr I forget all the mail server ports there is like 9xx ports that are used as well just a curiosity I used to have to do it like that for some odd reason when I could actually use port 25 and actually send mail. But I haven’t been able to send mail for a long time my ISP closed port 25 on me. So in fairness I’m a bit rusty on mail troubleshooting just something I recollect I had to do for a short time for whatever reason. Anyways just something to try better than nothing.
So basically what your saying is you’ve got your mail sending on other servers but those servers are not webmin servers they are using other software gotcha well hopefully they’ll find something but well I think there is a lot of little fires that need to be put out at the moment with webmin, virtualmin, cloudmin and hopefully your post helps lead to improvement and they discover something that’s worthwhile.
made another thread about that, diff topic
etc/network/interfaces I believe you are looking for the interfaces configuration file if I’m understanding your question correctly
Yeah its probably something like enp1s0 maybe can you use your terminal to check your interfaces
ipaddr
Type that see what you get for interfaces in root.
