Small Tutorial: How to Overcome an Issue when Restoring Emails via FTP on Virtualmin (Debian OS)
OS type and version Debian 12
Webmin version 2.610
Virtualmin version 7.50.2 GPL
Webserver version Nginx version 1.22.1
Related packages Dovecot
After reinstall my Virtualmin MAIL Server, I had my first experience in restore mails using the Virtualmin tools.
Because the way Virtualmin works to restore emails, that need to restore Full Users + Full Home directory, that I don’t like too much, since I just want to restore few emails and few users (not all), I decided to upload the emails myself via FTP.
I had some pain a head issues but I sorted it out. I’ll show the bugs I had and the steps to fix it:
Backup first before format your VPS:
Go to Virtualmin → Backup and Restore → Backup Virtual Servers
  • Select only one virtual server you want to backup (to have organized separated files - my opinion)
  • On “Features to backup” just check these two options: “Server’s home directory and web pages” and “Mail/FTP users and mail aliases”.
  • On “Backup destinations” select “Download via browser”.
  • Click on “Backup Now” and download the generated link.
Go to the file downloaded, extract it. Then after extract the inside file “example.com_dir.tar” - where are the server directories backup.
Go to this extracted folder with your FTP Program (I’m using Filezilla).
Virtualmin uses two Maildir folders structures to store emails:
  • /home/server_name/Maildir
  • /home/server_name/homes/info/Maildir
In my case, I only want to restore 2 folders in a specific mail user called “info”: “INBOX” and “Sent” folders. All the rest I want from the fresh new Virtualmin installation.
So the first folder to copy content from the backup to the server is:
/home/server_name/homes/info/Maildir/cur
The second folder is:
/home/server_name/homes/info/Maildir/.Sent/cur
After this my email client (Evolution on Linux) start to recover the emails.
I got this error every time I recovered a user/mail (I did 3 times and happened to me 3 times):
Some blank(corrupted) emails (not all), that can’t be deleted (there is a warn “this email can’t be moved…”) and if you do will break the Mail client (or lost this email if you succeeded):
  • I deleted the Email client cache in my computer, but the issue persisted.
How to fix it:
1) Rename the folders:
To:
/home/server_name/homes/info/Maildir/-cur
/home/server_name/homes/info/Maildir/.Sent/-cur
2) Change the “-cur” folder’s files permission to 644 (only files… folder keep 700)
chmod 644 /home/server_name/homes/info/Maildir/-cur/*
chmod 644 /home/server_name/homes/info/Maildir/.Sent/-cur/*
3) Close and Open Mail Client
After this refresh Maildir folders on FTP.
So new “cur” folders will be generated in Maildir.
4) Move all the files from “-cur” folder to “cur” folder
Do this for both “cur” folders (INBOX and Sent).
Email client will start to recover all emails with no issue.
CANCEL THIS STEP: 5) Move back permission to all files on “cur” folders to 600
CANCEL THIS STEP: chmod 600 /home/server_name/homes/info/Maildir/cur/*
CANCEL THIS STEP: chmod 600 /home/server_name/homes/info/Maildir/.Sent/cur/*
EDIT: Don’t back to 600. It makes emails to not fetch on mail client on the next day. When I back the restored emails to 644, all the emails fetched again properly on Mail Client. The new generated emails came in 600. I just left it the way it is and it is working fine until now.
That’s it. Have a great day!
thanks for this write up, it will be useful.
You welcome. I tried to change permission directly on “cur” folder but didn’t work. So I noticed I need to change the folder first, then to apply the change permission to make it to work properly.
I edited the last part to avoid issues on the next day.
