Simple question - backup
Usermin version 2.400
Virtualmin version 7.40.1
Theme version 25.10
Nginx version 1.22.1
ok, :face_with_open_eyes_and_hand_over_mouth:
when performing a backup (this is done so often by me that I frequently forget) :old_man:
Is there anywhere - templates perhaps - but :pensive_face:
to change/set the default to compression format and action on error
having just done a weekly backup on 5 VMs - yet again! I have found after the process they are either failed or in a useless format - simply because I forgot to change these settings - to the above
my head is telling me that somewhere it should be possible?
