I’m trying to migrate a Debian 6 32 Bit VPS to a Debian 6 64 Bit VPS, both on OpenVZ.
I followed the instructions on https://www.virtualmin.com/documentation/system/migrate. However, when I get to the “fun part” (exaclty: virtualmin restore-domain --source /root/backups/ --all-domains --all-features), the restore process fails with an “Out of memory” error message when the first home directory of the first virtual server is being extracted from the archive, even though only half of the real RAM is allocated and the swap isn’t even in use.
On the web-interface of Virtualmin, this action simply stops at the very same point without any error message.
To migrate the server anyway, I tried rsyncing the home directories and backed up the remaining configurations in the old file format using Virtualmin’s webinterface. Nevertheless, the restoration attempt fails, but with the error message “Restore failed : Failed to open /home/[USER]/fcgi-bin/php5.fcgi.webmintmp.5230 : Permission denied” when the Apache configuration is being restored. The access permissions of these files (error occurs with any virtual server) are 755. Strangely, I also cannot delete these files on the new VPS as root.
While this may seem silly, perhaps you could try restoring one domain at a time. Perhaps a bit more time consuming, but may allow for a bit more smooth migration if the machine is complaining about memory or any other resource. It’d also be at the very least a good way of troubleshooting, that is if the issue happens again during a single domain restore, perhaps there’s a bigger issue that needs to be addressed.
Hi Peter,
thanks for your quick response! Anyway, I forgot to mention that I already tried to migrate only one of the virtual servers (domains) at a time and encountered the very same errors.
The following is an excerpt of the listing of directory /home/[USER]/fcgi-bin/: -rwxr-xr-x 1 [USER] [GROUP] 219 Dec 13 06:50 php5.fcgi
Meanwhile, I also checked the user limits: root@myserver:~# ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 16382
max locked memory (kbytes, -l) 64
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) unlimited
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
AFAIK these settings shouldn’t be the reason for the out-of-memory problem.
Anyway, I am more interested in the second way to migrate the servers in order to decrease the downtime during migration. I should mention that I even tried to restore all configurations (without home directory) on Virtualmin’s web interface before rsyncing the home directory, but this failed either with the very same errore message (only the number in the file name behind “webmintmp” might have been different). Up to this point I would guess it is rather a problem with accessing these files in the backup archive. I would suppose they are not included in the archive since I did not include the home directory but the restoration routine tries to access them anyway. (The question may arise how I set up the restoration settings. Well, I chose “Only those selected below …” and selected everything except “Server’s home directory and web pages” in the “Features to restore” section. Additionally, I selected each option under “Virtualmin settings to restore”.)
However, the restoration process results in the same error if I use a full backup archive for restoration (new format including the home directories). Now the confusion is perfect as far as I’m concerned.
Hi Eric,
according to /proc/user_beancounters it looks as if the application actually ran out of memory while trying to restore the backup from the old server. Hence, do you have idea regarding the issue “Restore failed : Failed to open /home/[USER]/fcgi-bin/php5.fcgi.webmintmp.5230 : Permission denied”?
