Setting server IPs at home and setting the modem
was there anymore information below the ‘smtp transaction time’ where ti was giving a HELO interaction? eg
Connecting to 31.31.31.31
220 web.svchost.uk ESMTP Postfix (Ubuntu) [418 ms]
EHLO keeper-us-east-1d.mxtoolbox.com
250-myserver.ontheinternet.com
250-PIPELINING
250-SIZE 50000000
250-VRFY
250-ETRN
250-STARTTLS
250-AUTH PLAIN LOGIN
250-AUTH=PLAIN LOGIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250-DSN
250-SMTPUTF8
250 CHUNKING [403 ms]
MAIL FROM:<supertool@mxtoolboxsmtpdiag.com>
250 2.1.0 Ok [292 ms]
RCPT TO:<test@mxtoolboxsmtpdiag.com>
454 4.7.1 <test@mxtoolboxsmtpdiag.com>: Relay access denied [229 ms]
LookupServer 2645ms
where is this error, does it have anymore information?
do a health check
I am not an expert but I think you can contact your server from the internet. look at the top line, it is getting a response and telling you what your server is i.e posfix.
I am not sure why you cant send emails as you have not given any error messages.
Fix your RDNS / Reverse DNS as this will cause issues.
I have set DNS
It is the same problem again
I think it is from the internal and external IP settings
How should this section be set?
SSL certificate is not installed on IP
I selected the default SSL certificate option
It’s the same problem again
You cannot get a Let’s Encrypt certificate for an IP address. That’s a ridiculous thing to do.
Use names.
