I have recently set up a new email user
and have been using usermin.
I set up an auto reply
and also a forward to my gmail account,
but neigther seems to be working.
Here is what I set up:
After setting the auto reply and forwarding up
under Usermin, I went to VirtualMin under my main
administrator (for the whole server)
and looked at the user details for this user - I noticed that
no auto reply or forwarding was set - even though it appered
to be set in Usermin.
Why is that ? Surely they must show the same thing ?<br><br>Post edited by: Davvit, at: 2009/04/06 10:35
Hi Davvit
Did you manage to solve it ? I’ve about the same problem as you had.
My problem, when forwarded, it uses “localdomain” I’ve no idea how it works.
Normal, sending/receiving is no problem;
thanks
KH
This is my log
Aug 27 22:27:08 174 postfix/qmgr[3386]: 9DEB7F4C21: from=joan.testmd@localdomain, size=10085, nrcpt=1 (queue active)
Aug 27 22:27:08 174 postfix/smtp[10362]: 9DEB7F4C21: to=kcquilter@sbcglobal.net, relay=sbcmx6.prodigy.net[207.115.36.20]:25, delay=0.52, delays=0.26/0/0.19/0.06, dsn=5.1.8, status=bounced (host sbcmx6.prodigy.net[207.115.36.20] said: 553 5.1.8 joan.testmd@localdomain… Domain of sender address joan.testmd@localdomain does not exist (in reply to MAIL FROM command))
Aug 27 22:30:41 174 postfix/cleanup[13246]: C24CBF4C11: message-id=20090828022928.139D2F4C22@domU-12-31-38-00-2D-84.localdomain
Aug 27 22:30:41 174 postfix/local[10028]: 139D2F4C22: to=test.testmd@localdomain, relay=local, delay=74, delays=0.01/0/0/74, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Aug 27 22:30:41 174 postfix/qmgr[3386]: 139D2F4C22: removed
Aug 27 22:30:41 174 postfix/qmgr[3386]: C24CBF4C11: from=test.testmd@localdomain, size=9434, nrcpt=1 (queue active)
Aug 27 22:30:46 174 postfix/smtp[10362]: C24CBF4C11: to=khenghuatlim@time.net.my, relay=cuda2.time.net.my[203.121.65.119]:25, delay=4.9, delays=0.06/0/4.5/0.4, dsn=5.0.0, status=bounced (host cuda2.time.net.my[203.121.65.119] said: 504 Need Fully Qualified Address (in reply to MAIL FROM command))
Aug 27 22:30:47 174 postfix/cleanup[13246]: 71683F4C22: message-id=20090828023047.71683F4C22@domU-12-31-38-00-2D-84.localdomain
Aug 27 22:30:47 174 postfix/bounce[13809]: C24CBF4C11: sender non-delivery notification: 71683F4C22
