I’m guessing this has a lot to do with the way I’ve set up my server as I had issues with dns pointing to the internal address at one point.
So the problem is that after creating a virtualmin user I wanted to send emails. I managed to send an email from the domain server to another email account hosted elsewhere. But returning the email, or even sending a new email to the alias at my domain server doesn’t appear, the sender does not get a bounce or error.
What have I tried: I’ve sent an email from my alias at my domain to the same address (example me@mydomain.co.uk sent to me@mydomain.co.uk) and that sent but never returned.
I’ve done an on-line dns and mx scan to make sure that the server is resolving to the correct setting. It seems to
I’ve altered the host file in /etc/hosts so that it reflects my isp static ip I’m using. It now looks like this:
127.0.0.1 localhost.localdomain localhost
xx.xx.xx.xx mydomain.co.uk mydomain
(I’m actually using a real ip address not xx )
I used telnet mydomain.co.uk 25 and got a response so port 25 is open and can see my server.
I’m running Ubuntu 16.04.3 LTS and Virtualmin version 6.00 gpl usermin version 1.720 and webmin version 1.852
As I can't upload the file, here's a snippet of the mail log file in the hope that this is useful:
Sep 28 13:24:33 recom postfix/smtpd[18058]: warning: unknown[80.82.78.61]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:24:33 recom postfix/smtpd[18058]: disconnect from unknown[80.82.78.61] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Sep 28 13:27:08 recom postfix/smtpd[29640]: warning: hostname 82-76-210-60.rdsnet.ro does not resolve to address 82.76.210.60: Name $
Sep 28 13:27:08 recom postfix/smtpd[29640]: connect from unknown[82.76.210.60]
Sep 28 13:27:11 recom postfix/smtpd[29640]: warning: unknown[82.76.210.60]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:27:11 recom postfix/smtpd[29640]: disconnect from unknown[82.76.210.60] helo=1 auth=0/1 quit=1 commands=2/3
Sep 28 13:27:14 recom postfix/smtpd[29640]: connect from unknown[80.82.78.61]
Sep 28 13:27:17 recom postfix/smtpd[29640]: warning: unknown[80.82.78.61]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:27:17 recom postfix/smtpd[29640]: disconnect from unknown[80.82.78.61] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Sep 28 13:29:42 recom postfix/smtpd[32050]: connect from unknown[213.157.55.82]
Sep 28 13:29:45 recom postfix/smtpd[32050]: warning: unknown[213.157.55.82]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:29:45 recom postfix/smtpd[32050]: disconnect from unknown[213.157.55.82] helo=1 auth=0/1 quit=1 commands=2/3
Sep 28 13:29:59 recom postfix/smtpd[32050]: connect from unknown[80.82.78.61]
Sep 28 13:30:01 recom postfix/smtpd[32050]: warning: unknown[80.82.78.61]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:30:01 recom postfix/smtpd[32050]: disconnect from unknown[80.82.78.61] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Sep 28 13:31:32 recom postfix/anvil[2006]: statistics: max connection rate 1/60s for (smtp:95.97.101.138) at Sep 28 13:21:42
Sep 28 13:31:32 recom postfix/anvil[2006]: statistics: max connection count 1 for (smtp:95.97.101.138) at Sep 28 13:21:42
Sep 28 13:31:32 recom postfix/anvil[2006]: statistics: max cache size 2 at Sep 28 13:21:46
Sep 28 13:32:12 recom postfix/smtpd[9802]: connect from unknown[82.113.59.26]
Sep 28 13:32:15 recom postfix/smtpd[9802]: warning: unknown[82.113.59.26]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:32:15 recom postfix/smtpd[9802]: disconnect from unknown[82.113.59.26] helo=1 auth=0/1 quit=1 commands=2/3
Sep 28 13:32:42 recom postfix/smtpd[9802]: connect from unknown[80.82.78.61]
Sep 28 13:32:44 recom postfix/smtpd[9802]: warning: unknown[80.82.78.61]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:32:44 recom postfix/smtpd[9802]: disconnect from unknown[80.82.78.61] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Sep 28 13:35:55 recom dovecot: master: Dovecot v2.2.22 (fe789d2) starting up for imap, pop3, pop3 (core dumps disabled)
Sep 28 13:35:59 recom postgrey[1814]: Process Backgrounded
Sep 28 13:35:59 recom postgrey[1814]: 2017/09/28-13:35:59 postgrey (type Net::Server::Multiplex) starting! pid(1814)
Sep 28 13:35:59 recom postgrey[1814]: Resolved [localhost]:10023 to [::1]:10023, IPv6
Sep 28 13:35:59 recom postgrey[1814]: Resolved [localhost]:10023 to [127.0.0.1]:10023, IPv4
Sep 28 13:36:00 recom postgrey[1814]: Binding to TCP port 10023 on host ::1 with IPv6
Sep 28 13:36:00 recom postgrey[1814]: Binding to TCP port 10023 on host 127.0.0.1 with IPv4
Sep 28 13:36:00 recom postgrey[1814]: Setting gid to "125 125"
Sep 28 13:36:00 recom postgrey[1814]: Setting uid to "116"
Sep 28 13:36:19 recom postfix[2118]: Postfix is running with backwards-compatible default settings
Sep 28 13:36:19 recom postfix[2118]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Sep 28 13:36:19 recom postfix[2118]: To disable backwards compatibility use "postconf compatibility_level=2" and "postfix reload"
Sep 28 13:36:20 recom postfix/master[2162]: daemon started -- version 3.1.0, configuration /etc/postfix
Sep 28 13:37:27 recom postfix/smtpd[2564]: connect from unknown[92.240.252.85]
Sep 28 13:37:29 recom postfix/smtpd[2564]: warning: unknown[92.240.252.85]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:37:29 recom postfix/smtpd[2564]: disconnect from unknown[92.240.252.85] helo=1 auth=0/1 quit=1 commands=2/3
Sep 28 13:38:12 recom postfix/smtpd[2564]: connect from unknown[80.82.78.61]
Sep 28 13:38:14 recom postfix/smtpd[2564]: warning: unknown[80.82.78.61]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:38:14 recom postfix/smtpd[2564]: disconnect from unknown[80.82.78.61] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Sep 28 13:40:10 recom postfix/smtpd[3672]: connect from unknown[41.180.72.44]
Sep 28 13:40:13 recom postfix/smtpd[3672]: warning: unknown[41.180.72.44]: SASL LOGIN authentication failed: authentication failure
Sep 28 13:40:13 recom postfix/smtpd[3672]: disconnect from unknown[41.180.72.44] helo=1 auth=0/1 quit=1 commands=2/3
