Second IP address issues
Hi all,
I have purchased a second IP address for my dedicated server running CentOS7.
I’m just having a bit of job getting it set up and was hoping for some advice.
So, I have two virtual servers on there, initially both share the same IP address (same IP address as the webmin/virtualmin interface).
I have the second IP address now and want to assign it to one of the virtual servers.
So far I have done the following:
Webmin -> Network Configuration -> Network Interface -> Edited EM1 (Ethernet), and added the new IP address as a Virtual Interface.
I then opened Server Configuration and then Change IP Address against the Virtual Server that I want to use this IP.
In the Use Dedicated Address field, i entered the IP address and ticked ‘Already Active’.
I thought that would be all I needed to do, but when I go to the IP address, it doesn’t load and says This Site can’t be reached.
One thing I noticed is that when I go back to network interface, and then EM1, there is no mention of the virtual interface I added.
So i’m not sure if this is an issue.
Can anyone shed any light?
Much appreciated.
Thanks,
Craig
