Searh syntax for Virtualmin UI logfiles
I am trying to find information on what syntax to use in the Virtualmin log file component. I can search for individual words but I want to know how to do a combined search in the UI.
You can use regular expressions in the search field, as well. A simple wildcard is .*, so if I wanted to search for bingbot and bikinibot (a made up bot for the sake of this example) I could do something like bi.*bot
Thank you so much I will give that a try.
I like the way you think. :bikini:
