Scheduled Monitoring Hangs
OS type and version AlmaLinux 9.3
Webmin version 7.10.0 Pro
I am experiencing the same problem.
I go to Tools > System and Server Status > click “Scheduled Monitoring” and the red progress bar at top fills up, bounces back and forth, and nothing happens.
Any suggestions? Would any logs be helpful?
Turned out to be my browser.
I’m using Opera for my WM/VM stuff. Everything else seems to work so kinda strange this one thing failed.
Mine does not work with chrome but works with firefox so there doesn’t seem to be a pattern
And Chrome was the one that worked for me.
I wonder if something is written to browser local storage or some form of cookie somewhere that stops the schedule showing… IDK, but tbf if you start looking at the rendered html there are loads of elements that don’t have ID’s so there could be some js function somewhere that is hanging because it can not find the right element
