Saslauthd not working after Ubuntu 24 upgrade
OS type and version Ubuntu 24.05.5
Virtualmin version 8.3.0
Everything has been working fine for years and I’ve finally got around to upgrading my Ubuntu 22 server to 24 but am having a few issues with saslauthd.
I followed the upgrade advice in..
but it just seems to reject logins for email. Incoming works fine, but I’m unable to send.
In the log I get..
warning: SASL authentication failure: cannot connect to saslauthd server: No such file or directory
I’ve created the symlink from
ln -s /var/spool/postfix/var/run/saslauthd /var/run/saslauthd
but it doesn’t seem to stick after sasl is restarted.
testsaslautd works with success using -f /var/spool/postfix/var/run/saslauthd/mux
Any help is appreciated!
So I got it running temporarily last night using Dovecot as auth and all worked fine, however wanted to get Cyrus working properly.
As everything seemed to be working just not communicating together, I editted /etc/postfix/sasl/smtpd.conf and added..
saslauthd_path: /var/spool/postfix/var/run/saslauthd/mux
Restarted Postfix and everything works perfectly.
