I’m having a bit of difficulties finding a simple, straight answer, so hope somebody can help me clear it out:
Can one website exist on the same IP for both SSL and non SSL version in Virtualmin? If so, how should it be set up?
Thanks!
Thanks!
Well, sure – that’s the normal default. Just set up an SSL server in Virtualmin. If you’re having a problem with that then I guess you’d need to say what the problem is. They will be on the same IP address but different ports.
