I made quick test and the problem is with your selected SSLCipherSuite, plus probably some other SSL settings. You will need to dig into httpd.conf and ssl.conf and see what you have there.
Browsers are still using TLSv1 and TLSv1.1 (especially mobile versions) so you should keep them enabled.
Not sure what did you change but last time i check your website the only problem was with SSLCipherSuite and based on the test results this was the only thing you needed to modify.
