Hi Stefan,
Thanks for the reply. This doesn’t seem to be the experience I am getting… I’m very much on the newbie side of the curve here, so don’t feel it’s anything I could have changed, for fear of breaking stuff.
I’ve two new VPS servers, both only 10 days old (all updated to the latest versions of everything).
Test server is blue.itwatch.co.uk live server is leo.itwatch.co.uk (itwatch.co.uk DNS is handled externally, with that zone file pointing to these two servers). I have created a VS on each server to match the server name (this is the default VS if just the IP address is used). Under these VSs I have installed the roundcube script.
So by going to blue .itwatch.co.uk/roundcube or leo .itwatch.co.uk/roundcube (space added so this don’t show the destination rather than the address) I’ll be presented with a roundcube login prompt (and I can obviously use the details for any mail enabled account on any domain to login to roundcube mail from this prompt).
Now if attempt to go to webmail.bourboncollection.com (a VS on blue.itwatch.co.uk, that does have roundcube added as a script), I am forwarded to roundcube under blue.itwatch.co.uk.
If I go to webmail.fashionrail.com (a domain that only has DNS and Apache enabled, no e-mail), it too forwards to roundcube under blue.itwatch.co.uk
and another domain webmail.spectrumgalway.com (enabled for mail, but no roundcube script installed). This too forwards to roundcube under blue.itwatch.co.uk.
I’ve many other VSs setup on that server, and they all forward as above…
So I decided to test if it was the same results under the live server, and it seems to be…
webmail.gragnola.com forwarding to leo .itwatch.co.uk/roundcube (and gragnola VS has no roundcube script). Other VSs domain on this server all forward to the roundcube folder as above.
I don’t mind this result at all, but I was concerned there maybe something I was doing wrong, and that I should have the roundcube script installed under every VS that had mail enabled…
