hansi
September 4, 2023, 6:41pm
1
OS type and version
Debian Linux 11
Roundcube version
1.5.3
Hello when i want to send a email to a gmail account i get this error
This is the mail system at host Redactet.
OS type and version
Debian Linux 11
Roundcube version
1.5.3
Error says it all, DMARC policy is failing, have you set a dmarc and if so is it at reject if something fails?
This isn’t a roundcube issue so you have created a wrong name for this message.
xlad
September 4, 2023, 10:43pm
3
Take no action until DMARC policies could be enforced, usually until your keys and the rest propagate.
You ask the mails to be rejected…
Check your propagation status at: https://www.whatsmydns.net/
CHeck your SMTP config at: SMTP Test / Mail Server Test • Wormly Monitoring
mxtoolbox
Domain DNS Validation - Free DNS Health Check Service
Hope that helps, good luck.
hansi
September 5, 2023, 12:07am
4
i fix it now i got a nother problem i can send emails now to gmails but the other way not
Use https://mxtoolbox.com/ to find issues with domain.
hansi
September 5, 2023, 1:16am
6
i dont find the error can i connect my domain with the dns records ?
Post the mxtools error if there is one.
hansi
September 5, 2023, 3:46am
8
You need to setup the DNS setting. You haven’t posted your system setup.
Some docs to help
https://www.virtualmin.com/documentation/dns/troubleshooting/
https://www.virtualmin.com/documentation/dns/faq/
If you don’t have dns setup nothing will work.
hansi
September 5, 2023, 4:07am
10
when i want to send a email i get this SMTP Error (554): Der Empfänge “Gmail email” konnte nicht gesetzt werden (5.7.1 : Relay access denied).
Create a new post, the post name is actually nothing to do with Roundcube,
system
Closed
November 4, 2023, 4:10am
12
