Administrators should promptly update their Roundcube webmail installations to the latest version. The developers have fixed a security vulnerability in recent releases that could allow malicious code to be executed on affected systems.
According to this, the “critical” vulnerability (CVE-2025-49113) has been patched in versions 1.5.10 and 1.6.11. All earlier versions are believed to be vulnerable.
Although the flaw is rated as critical, attackers must be authenticated to exploit it. The issue arises because the _from parameter in URLs pointing to `program/actions/settings/upload.php is not properly validated, allowing attackers to execute their own code.
A successful attack is likely to result in full compromise of the affected instance.
