root password problem... while creating a virtual host.
I get this message when I am trying to create a virtual server: Failed to create virtual server : DBI connect failed : Access denied for user ‘root’@‘localhost’ (using password: YES)
WHAT am I doing wrong? YES is not root’s password. I can make it that.
what operating system are you running?
That is an error message from MySQL, refusing root login. Did you install Virtualmin using the installer script? Did you perform the first-run wizard which asks you for the MySQL root password?
