Root kills dovecot. Why?
in irregular intervals, dovecot on my virtualmin host dies. Looking into the logs, I see, that it is killed w. Signal 15 (= SIGTERM) by root (UID 0 with different PID’s). Obviously not a cron, as the times vary. I never had such a situation on any of our servers and I am wondering why this happens, resp. how it can be prevented, thank you
:/var/log# zgrep 'Warning: Killed with signal 15' *
mail.info:Jun 9 14:27:41 io dovecot: master: Warning: Killed with signal 15 (by pid=21204 uid=0 code=kill)
mail.info:Jun 10 12:59:21 io dovecot: master: Warning: Killed with signal 15 (by pid=7372 uid=0 code=kill)
mail.info:Jun 10 13:47:57 io dovecot: log(20059): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
mail.info.1:Jun 1 12:33:52 io dovecot: master: Warning: Killed with signal 15 (by pid=1562 uid=0 code=kill)
mail.info.1:Jun 5 22:41:19 io dovecot: master: Warning: Killed with signal 15 (by pid=19545 uid=0 code=kill)
mail.info.2.gz:May 24 13:17:45 io dovecot: master: Warning: Killed with signal 15 (by pid=30179 uid=0 code=kill)
mail.info.2.gz:May 25 15:55:41 io dovecot: master: Warning: Killed with signal 15 (by pid=29685 uid=0 code=kill)
mail.info.2.gz:May 25 17:26:36 io dovecot: master: Warning: Killed with signal 15 (by pid=13304 uid=0 code=kill)
mail.info.2.gz:May 30 13:21:12 io dovecot: master: Warning: Killed with signal 15 (by pid=6975 uid=0 code=kill)
mail.info.3.gz:May 21 18:31:26 io dovecot: master: Warning: Killed with signal 15 (by pid=30501 uid=0 code=kill)
mail.info.3.gz:May 21 18:31:28 io dovecot: log(14091): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
mail.info.3.gz:May 21 18:31:59 io dovecot: master: Warning: Killed with signal 15 (by pid=1242 uid=0 code=kill)
mail.info.3.gz:May 23 14:25:40 io dovecot: master: Warning: Killed with signal 15 (by pid=27521 uid=0 code=kill)
mail.info.3.gz:May 23 14:25:50 io dovecot: master: Warning: Killed with signal 15 (by pid=28464 uid=0 code=kill)
mail.log:Jun 9 14:27:41 io dovecot: master: Warning: Killed with signal 15 (by pid=21204 uid=0 code=kill)
mail.log:Jun 10 12:59:21 io dovecot: master: Warning: Killed with signal 15 (by pid=7372 uid=0 code=kill)
mail.log:Jun 10 13:47:57 io dovecot: log(20059): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
mail.log.1:Jun 1 12:33:52 io dovecot: master: Warning: Killed with signal 15 (by pid=1562 uid=0 code=kill)
mail.log.1:Jun 5 22:41:19 io dovecot: master: Warning: Killed with signal 15 (by pid=19545 uid=0 code=kill)
mail.log.2.gz:May 24 13:17:45 io dovecot: master: Warning: Killed with signal 15 (by pid=30179 uid=0 code=kill)
mail.log.2.gz:May 25 15:55:41 io dovecot: master: Warning: Killed with signal 15 (by pid=29685 uid=0 code=kill)
mail.log.2.gz:May 25 17:26:36 io dovecot: master: Warning: Killed with signal 15 (by pid=13304 uid=0 code=kill)
mail.log.2.gz:May 30 13:21:12 io dovecot: master: Warning: Killed with signal 15 (by pid=6975 uid=0 code=kill)
mail.log.3.gz:May 21 18:31:26 io dovecot: master: Warning: Killed with signal 15 (by pid=30501 uid=0 code=kill)
mail.log.3.gz:May 21 18:31:28 io dovecot: log(14091): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
mail.log.3.gz:May 21 18:31:59 io dovecot: master: Warning: Killed with signal 15 (by pid=1242 uid=0 code=kill)
mail.log.3.gz:May 23 14:25:40 io dovecot: master: Warning: Killed with signal 15 (by pid=27521 uid=0 code=kill)
mail.log.3.gz:May 23 14:25:50 io dovecot: master: Warning: Killed with signal 15 (by pid=28464 uid=0 code=kill)
mail.warn:Jun 9 14:27:41 io dovecot: master: Warning: Killed with signal 15 (by pid=21204 uid=0 code=kill)
mail.warn:Jun 10 12:59:21 io dovecot: master: Warning: Killed with signal 15 (by pid=7372 uid=0 code=kill)
mail.warn:Jun 10 13:47:57 io dovecot: log(20059): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
mail.warn.1:Jun 1 12:33:52 io dovecot: master: Warning: Killed with signal 15 (by pid=1562 uid=0 code=kill)
mail.warn.1:Jun 5 22:41:19 io dovecot: master: Warning: Killed with signal 15 (by pid=19545 uid=0 code=kill)
mail.warn.2.gz:May 24 13:17:45 io dovecot: master: Warning: Killed with signal 15 (by pid=30179 uid=0 code=kill)
mail.warn.2.gz:May 25 15:55:41 io dovecot: master: Warning: Killed with signal 15 (by pid=29685 uid=0 code=kill)
mail.warn.2.gz:May 25 17:26:36 io dovecot: master: Warning: Killed with signal 15 (by pid=13304 uid=0 code=kill)
mail.warn.2.gz:May 30 13:21:12 io dovecot: master: Warning: Killed with signal 15 (by pid=6975 uid=0 code=kill)
mail.warn.3.gz:May 21 18:31:26 io dovecot: master: Warning: Killed with signal 15 (by pid=30501 uid=0 code=kill)
mail.warn.3.gz:May 21 18:31:28 io dovecot: log(14091): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
mail.warn.3.gz:May 21 18:31:59 io dovecot: master: Warning: Killed with signal 15 (by pid=1242 uid=0 code=kill)
mail.warn.3.gz:May 23 14:25:40 io dovecot: master: Warning: Killed with signal 15 (by pid=27521 uid=0 code=kill)
mail.warn.3.gz:May 23 14:25:50 io dovecot: master: Warning: Killed with signal 15 (by pid=28464 uid=0 code=kill)
syslog:Jun 10 12:59:21 io dovecot: master: Warning: Killed with signal 15 (by pid=7372 uid=0 code=kill)
syslog:Jun 10 13:47:57 io dovecot: log(20059): Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
syslog.1:Jun 9 14:27:41 io dovecot: master: Warning: Killed with signal 15 (by pid=21204 uid=0 code=kill)
syslog.5.gz:Jun 5 22:41:19 io dovecot: master: Warning: Killed with signal 15 (by pid=19545 uid=0 code=kill)
Also I have dovecot down after a login error.
Maybe something related about last update? I see many topic about dovecot
This error occurs if there are any hung dovecot processes. RUN COMMAND
for i in ps aux | grep dovecot | awk '{print $2}' ; do kill -9 $i ; done
Now start dovecot start script.
