I’ve just re-setup our secondary mx/dns and i’m having problems getting RNDC to work.
When i try to force an update on a zone i get
NDC command failed : rndc: connection to remote host closed This may indicate that the remote server is using an older version of the command protocol, this host is not authorized to connect, or the key is invalid.
If i click "Setup RNDC" i get
Failed to setup RNDC : Could not find key in rndc.conf
My named.conf looks like this
options {
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
include "/etc/rndc.key";
…zones follow
And this is my rndc.key file
key rndckey {
algorithm hmac-md5;
secret "4bNunXdbX2I88HMrUhEBkNSZEPYFYHlXpm315Tm1d78BUUpsSSeq1LomhQit";
I get the following message in /var/log/messages when i try to force an update
invalid command from 127.0.0.1#33970: bad auth
but zone do seem to transfer ok
Aug 19 19:11:32 hostname named[[23877]]: zone domain.co.uk/IN: transferred serial 1131107961
Aug 19 19:11:32 hostname named[[23877]]: transfer of ‘domain.co.uk/IN’ from xxx.xxx.xxx.xxx#53: end of transfer
So it seems there is a problem with the key setup, but i don’t fully understand what i’m looking at to be able to tinker with it
Both boxes are RHEL4, bind/rndc 9.2.4 and fully updated.
